Changes between Version 2 and Version 3 of PerformanceImprovementInSearch
- Sep 3, 2009, 4:20:57 AM (15 years ago)
v2 v3 45 45 A second performance gain is effected by a change to retrieving the regions data in the search service. In standard GeoNetwork, the regions are retrieved from the DB at each search request; in this proposal, it happens only once, after which the regions data is kept in memory for application lifetime. 46 46 47 Performance metrics from !YourKit Java Profiler show that this change leads to a 90% performance increase of the search service as such (excluding the creation of the search results page).47 Performance metrics from !YourKit Java Profiler show that this change leads to a 90% performance increase of the search service as such (excluding the request and response handling in the Web application framework surrounding it). 48 48 49 49 TODO Jeroen says: add list of all search parameters (why? they don't change in this proposal)
