71 | | There is no editing interface that helps the user create aggregateInformation elements representing sibling relationships. Instead, the user is expected to use the advanced editor to expand the aggregateInformation element manually and add in the required content. The search widget for the parentIdentifier could be adapted to help the user to search for sibling metadata records. |
| 71 | To create aggregateInformation elements representing sibling relationships, the user would use the advanced editor to expand the aggregateInformation element manually and: |
| 72 | * search for and select a sibling metadata record whose UUID will become the aggregateDataSetIdentifier (The search widget for the parentIdentifier is used for this purpose) |
| 73 | * select 'crossReference' as the associationType |
| 74 | * select an appropriate initiativeType to describe the sibling relationship |
