69 | | * in the java code underlying the GetRelated guiservice. A simple XPath extraction for all aggregateInformation elements that have an aggregateDataSetIdentifier with a code, an associationType with value set to crossReference and an initiativeType is used to assemble the list of codes (UUIDs/URNs). Sibling metadata records are extracted from the database and attached to the XML output of the GetRelated guiservice. |
70 | | * add processing of the GetRelated output in relations.xsl which is used in the xml.relation service - returns a simple/brief view of the related records. |
| 69 | * in the java code underlying the !GetRelated guiservice. A simple XPath extraction for all aggregateInformation elements that have an aggregateDataSetIdentifier with a code, an associationType with value set to crossReference and an initiativeType is used to assemble the list of codes (UUIDs/URNs). Sibling metadata records are extracted from the database and attached to the XML output of the !GetRelated guiservice. |
| 70 | * add processing of the !GetRelated output in relations.xsl which is used in the xml.relation service - returns a simple/brief view of the related records. |
