Changes between Version 11 and Version 12 of MEFImprovement
- Nov 18, 2009, 12:57:58 PM (15 years ago)
MEFImprovement
v11 v12 69 69 | +--- (optional) metadata.profil.xml (ISO19139profil) 70 70 +--- info.xml 71 +--- overviews72 71 +--- applischema 73 72 | +--- (optional) schema.xml (ISO19110) … … 96 95 A preferred schema parameter is added to config in order to define which file to load when more than on file is found in a MEF file. If no record with preferred schema found, use first valid one (in a schema known by current node). 97 96 98 === Other minor changes to import/export services === =97 === Other minor changes to import/export services === 99 98 * Stylesheet parameter is not mandatory (default is none) 100 99 * Category parameter is not mandatory (default is none)
