Changes between Version 9 and Version 10 of MEFImprovement
- Nov 16, 2009, 5:24:50 AM (15 years ago)
MEFImprovement
v9 v10 87 87 In some situation a child or related service may have different user privileges. If related records are not accessible for current user, they are not exported. 88 88 89 Format parameter (simple, partial, full) is also supported in V2. 90 89 91 === MEF Import === 90 92 A preferred schema parameter is added to config in order to define which file to load when more than on file is found in a MEF file. If no record with preferred schema found, use first valid one (in a schema known by current node).
