Changes between Version 9 and Version 10 of LoadBalanceable
- Apr 13, 2012, 5:28:33 AM (12 years ago)
LoadBalanceable
v9 v10 43 43 A notion exists that database perform faster if their (foreign) keys are auto-incremented integers, not strings. However if you google it, opinions whether this is really the case vary wildly and almost no-one offers actual measurements. [http://krow.livejournal.com/497839.html Here] is a post that does show measurements in MySQL which is re-assuring. Also, a change to String UUIDs allows for the removal of thousands of places in the GeoNetwork Java code where integers are converted to strings and vice-versa. Removing those increases performance because they're no longer done, and fewer short-lived objects are created which can help speed up garbage collection delays. 44 44 45 === uploaded files===45 === shared data directory === 46 46 GeoNetwork creates directories for uploaded data that's associated with a metadata. The names of these (sub-)directories are calculated from the value of the metadata's database ID, probably to avoid having a totally flat structure with too many subdirectories. To support both new UUID-based and old integer-based IDs, the code doing this calculation will be modified so that it recognizes whether an ID is old or new; for old IDs, it uses the existing calculation method. For new IDs it generates a directory name that's /ab/cd/ef, using the first 6 characters of the ID. As UUIDs really are hexadecimal numbers, each (sub-)directory will have maximally 16*16 = 256 subdirectories, and the 3-level nesting creates room for in total 256^3 = 16,777,216 metadata records with uploaded files. If you think it's not safe we could make it 4 levels, supporting 4,294,967,296 metadata. 47 47 48 === synchronization between nodes === 49 In order to propagate changes made in one node to all others, each time the Lucene index (and SVN) is updated in one node, when a metadata changes, a message is sent to all other nodes causing them to do the same (note: this does not involve a full rebuild-index, just a re-index of the changed metadata -- equal to what happens in the originating node). 48 In addition, each node has its own, local directories for Lucene, SVN and Cluster Configuraton (this last folder just contains a unique identifier of the node). 50 49 51 We'll use JMS to propagate these message using durable subscriptions to a Topic/Subscribe queue. This decouples knowledge of the other nodes from each node and enables guaranteed delivery in correct order even after a node has been down. 50 === synchronization between nodes: JMS topics === 51 52 In order to propagate changes made in one node to all others, JMS messages are placed on !Topic/Subscribe channels. Each node is also using durable subscriptions to each topic. This decouples knowledge of the other nodes from each node and enables guaranteed delivery in correct order even after a node has been down. 53 54 Messages published to these topics are received by all nodes in the cluster. If a node is down, it will receive the messages 55 published during its absence when it comes back up, in correct order. When all nodes have read the message, it will be removed 56 from the topic (at some point). 57 58 The topics are: 59 60 - RE-INDEX 61 Used to synchronize the nodes' Lucene indexes when metadata is added, deleted, updated, its privileges change, etc. 62 63 - OPTIMIZE-INDEX 64 Used to propagate the Optimize Index command to all nodes. 65 66 - RELOAD-INDEX-CONF 67 Used to propagate the Reload Index Configuration command to all nodes. 68 69 - SETTINGS 70 Used to propagate a change in Settings to all nodes. 71 72 - ADD-THESAURUS 73 74 - DELETE-THESAURUS 75 76 - ADD-THESAURUS-ELEMENT 77 78 - UPDATE-THESAURUS-ELEMENT 79 80 - DELETE-THESAURUS-ELEMENT 81 82 - MD-VERSIONING 83 Used to invoke the nodes' SVN versioning control. 84 85 - HARVESTER 86 Used to propagate changes to Harvesters to all nodes. 87 88 - SYSTEM_CONFIGURATION 89 Used to request all nodes to publish their System Information. 90 91 - SYSTEM_CONFIGURATION_RESPONSE 92 Used to publish System Information. 93 94 === synchronization between nodes: JMS queues === 95 96 Messages published to these queues are received by one single node in the cluster. This can be any one of the nodes, whichever 97 is first. When a node reads a message it is removed from the queue. 98 99 The queues are: 100 101 - HARVEST 102 Used to run a Harvester. When clustering is enabled, a Harvester that's set to run periodically is invoked by periodic 103 publication of a message to this queue; any one of the nodes in the cluster that picks it up first, will actually run 104 the Harvester. 105 52 106 53 107 === site uuid === 54 108 The site uuid identifies this catalog. It's generated at start-up of a GeoNetwork node. We should prevent this happening more than once (e.g. if months later an extra node is added, it should not change). To achieve this, it will be inserted by the insert-data SQL scripts with a value of CHANGEME. When any node in the cluster starts up it checks the value and only if it is still CHANGEME, will it update its value to a UUID. 55 109 56 === harvesters ===57 Since the harvesting configuration is stored inside the database, all GeoNetwork instances inside the cluster will share the same harvesting configuration and will hence all attempt to harvest the same nodes.58 59 To prevent the associated overhead in memory footprint and performance, the harvester configurations will be extended with a field containing the node-uuid of the GeoNetwork node where it was created. The harvesting schedule will run only in this node. To improve distribution of load, the scheduler will not start the harvest job as such, but places a message on a JMS Point-to-Point queue. All nodes are registered with this queue and one of them will be the first to pick it up, removing the message from the queue and starting the harvester job.60 61 An admin function to check sanity (signal harvesters with a node-uuid that doesn't exist in the new nodes table) will allow Administrator users to replace the node-uuid with one that does exist in the nodes table.62 63 110 === edit metadata lock === 64 111 When a metadata is being edited by one user, and then another user also opens it for editing, the second user cannot save his changes because GeoNetwork maintains an in-memory 'version-number' to prevent this from happening. In a clustered scenario the in-memory version number is not globally available so this strategy must change. 65 112 66 The current implementation is in effect a form of pessimistic locking (concurrent edit sessions cannot successfully save), with additional disadvantage that the users are not informed when they start editing that they will lose their changes. This will be replaced by a more direct form of pessimistic locking, making it impossible to open a metadata for editing if it is being edited already at that moment. Admin functions will be available to force unlock metadata. 113 The current implementation is in effect a form of pessimistic locking (concurrent edit sessions cannot successfully save), with additional disadvantage that the users are not informed when they start editing that they will lose their changes. This will be replaced by a more direct form of pessimistic locking, making it impossible to open a metadata for editing if it is being edited already at that moment. Admin functions will be available to force unlock metadata. 114 115 NOTE: this will not be implemented in the scope of this proposal; rather, we'll soon publish a separate proposal dedicated to improvements in locking, lifecycle and metadata state. 67 116 68 117 === settings === 69 When settings are modified from one GN node, the other nodes will be out of date because the settings are kept in memory from startup. To prevent this we propose two alternatives: 118 Administrator users can enable clustering in the System Configuration. When enabled, a URL to the !ActiveMQ JMS server needs to be specified. 70 119 71 * no longer keep the settings in memory, but look them up everytime. This costs a bit more DB selects of course, but with an index on the unique column these simple selects should not take too long. This would also allow us to delete !SettingManager, which we have wanted to do for a long time. 72 * alternatively, a second update-broadcast to the peer nodes can instruct them to re-initialize !SettingManager. 73 74 Your opinions on this are welcome. 120 === documentation === 121 See the GeoNetwork User Documentation for a description of how to install and configure a cluster. 75 122 76 123 77 124 === Backwards Compatibility Issues === 78 Are there any ? 125 126 Any clients relying on the integer nature of database IDs, if they exist, need to change so they expect UUIDs instead. 79 127 80 128 === New libraries added === 81 129 ActiveMQ for JMS 130 131 == Test cluster == 132 133 We have a fully functional !GeoNetwork cluster which uses 2 physical machines hosting 4 !GeoNetwork nodes in 2 Tomcats and 1 Jetty. The nodes are not load-balanced to facilitate testing propagation between nodes. You may access the test nodes at [http://dev.ace.geocat.net:7080/geonetworkn1 1], [http://dev.ace.geocat.net:7080/geonetworkn2 2], [http://dev.ace.geocat.net:7070/geonetwork 3] and [http://78.46.99.131:7080/geonetwork 4]. 134 135 We do not guarantee anything about this test cluster and we'll take it down soon without notice. 82 136 83 137 == Risks ==
