Changes between Version 2 and Version 3 of JMeterModule
- Sep 14, 2012, 7:29:01 AM (12 years ago)
JMeterModule
v2 v3 48 48 || mvn install || jmeter || Start Geonetwork in embedded jetty and run jmeter tests against instance || 49 49 || mvn site:run || jmeter || Run the maven site jetty on port 9000. The performance reports are under the Reports section || 50 || mvn install -P performance|| root directory || Build geonetwork and run jmeter tests ||50 || mvn install -P jmeter || root directory || Build geonetwork and run jmeter tests || 51 51 || mvn install -P -jmeter-jetty install || jmeter || Run jmeter tests but do not start embedded jetty || 52 52 || mvn install -P -jmeter-jetty -Dtestserver.host=otherserver.com -Dtestserver.port=80 install || jmeter || Run jmeter tests (no jetty) against http://otherserver.com:80/geonetwork||
