Changes between Version 2 and Version 3 of InterTrac
- Apr 22, 2015, 3:15:37 PM (9 years ago)
InterTrac
v2 v3 1 = InterTrac Links =1 = InterTrac Links 2 2 3 Trac supports a convenient way to refer to resources of other Trac servers, from within the Wiki markup , since version 0.10.3 Trac supports a convenient way to refer to resources of other Trac servers, from within the Wiki markup. An !InterTrac link can be seen as a scoped TracLinks. It is used for referring to a Trac resource located in another Trac environment. A resource can be a wiki page, changeset, ticket or milestone. 4 4 5 == Definitions == 6 7 An InterTrac link can be seen as a scoped TracLinks. 8 It is used for referring to a Trac resource 9 (Wiki page, changeset, ticket, ...) located in another 10 Trac environment. 11 12 == List of Active InterTrac Prefixes == 5 == List of Active InterTrac Prefixes 13 6 14 7 [[InterTrac]] 15 8 16 == Link Syntax ==9 == Link Syntax 17 10 18 Simply use the name of the other Trac environment as a prefix, 19 followed by a colon, ending with the resource located in the other environment. 11 Simply use the name of the other Trac environment as a prefix, followed by a colon, ending with the resource located in the other environment. 20 12 21 13 {{{ … … 25 17 The other resource is specified using a regular TracLinks, of any flavor. 26 18 27 That target environment name is either the real name of the 28 environment, or an alias for it. 19 That target environment name is either the real name of the environment or an alias for it. 29 20 The aliases are defined in `trac.ini` (see below). 30 21 The prefix is case insensitive. 31 22 32 When a TracLink is enclosed in brackets, the alias is expanded. That is, `[th:ticket:1]` is displayed as `trachacks:ticket:1`, since `th` is an alias for `trachacks`. If the TracLink is not enclosed in brackets, then the alias is displayed as it is typed.23 If the InterTrac link is enclosed in square brackets (like `[th:WikiExtrasPlugin]`), the InterTrac prefix is removed in the displayed link like a normal link resolver would be, ie the above would be displayed as `WikiExtrasPlugin`. 33 24 34 For convenience, there's also some alternative short-hand form, 35 where one can use an alias as an immediate prefix 36 for the identifier of a ticket, changeset or report: 37 (e.g. `#T234`, `[T1508]`, `[trac 1508]`, ...) 25 For convenience, there's also some alternative short-hand form, where one can use an alias as an immediate prefix for the identifier of a ticket, changeset or report, eg `#T234`, `[T1508]`, `[trac 1508]`. 38 26 39 == Examples ==27 == Examples 40 28 41 29 It is necessary to setup a configuration for the InterTrac facility. … … 43 31 44 32 Example configuration: 45 {{{ 46 ... 33 {{{#!ini 47 34 [intertrac] 48 35 # -- Example of setting up an alias: … … 55 42 56 43 The `.url` is mandatory and is used for locating the other Trac. 57 This can be a relative URL in case that Trac environment is located 58 on the same server. 44 This can be a relative URL in case that Trac environment is located on the same server. 59 45 60 The `.title` information will be used for providing an useful tooltip 61 when moving the cursor over an InterTrac links. 46 The `.title` information will be used for providing an useful tooltip when moving the cursor over an InterTrac links. 62 47 63 48 Finally, the `.compat` option can be used to activate or disable … … 67 52 link, and it's up to the local Trac to prepare the correct link. 68 53 Not all links will work that way, but the most common do. 69 This is called the compatibility mode, and is ` true` by default.54 This is called the compatibility mode, and is `false` by default. 70 55 * If you know that the remote Trac knows how to dispatch InterTrac links, 71 56 you can explicitly disable this compatibility mode and then ''any'' … … 89 74 * finally, to link to the start page of a remote trac, simply use its prefix followed by ':', inside an explicit link. Example: `[th: Trac Hacks]` (''since 0.11; note that the ''remote'' Trac has to run 0.11 for this to work'') 90 75 91 The generic form `intertrac_prefix:module:id` is translated 92 to the corresponding URL `<remote>/module/id`, shorthand links 93 are specific to some modules (e.g. !#T234 is processed by the 94 ticket module) and for the rest (`intertrac_prefix:something`), 95 we rely on the TracSearch#quickjump facility of the remote Trac. 76 The generic form `intertrac_prefix:module:id` is translated to the corresponding URL `<remote>/module/id`, shorthand links are specific to some modules (e.g. !#T234 is processed by the ticket module) and for the rest (`intertrac_prefix:something`), we rely on the TracSearch#quickjump facility of the remote Trac. 96 77 97 78 ----
