Changes between Version 8 and Version 9 of ISO2ebRIMIssues
- Mar 8, 2009, 6:35:29 AM (15 years ago)
ISO2ebRIMIssues
v8 v9 30 30 - identificationInfo : "In this profile, the cardinality of this property is restricted to 1..1 for the ISO 19139 metadata files stored in the ebRIM Repository." Very good, but what to do with perfectly valid ISO19139 documents that have more than 1 identificationInfo ? Then in again, in Table F.2 it is stated to apply the Section F.3 transformation to "each instance of the property (identificationInfo)". I'm doing it for-each, now. 31 31 32 - Section F.3.1 distinguishe d !DataSet/DatasetCollection, Service and Application types of Information Resource by the value of 'hierarchyLevel'. In ISO19139 it is perfectly valid to have 0 or more than 1 hierarchyLevel. What to do in these cases ??? For now, I'm just using the first one if there are more, and if there are zero, try 'DataSet'.32 - Section F.3.1 distinguishes !DataSet/DatasetCollection, Service and Application types of Information Resource by the value of 'hierarchyLevel'. In ISO19139 it is perfectly valid to have 0 or more than 1 hierarchyLevel. What to do in these cases ??? For now, I'm just using the first one if there are more, and if there are zero, try '!DataSet'. 33 33 34 34
