8 | | * Create new record in 'languages' table in your GeoNetwork's database. |
9 | | * In all tables which name ends with 'Des' copy all entries marked |
10 | | 'en' (or any other language) to entries with new language code. Then |
11 | | you will be able to edit these fields using Web-interface. |
12 | | * Copy folders (all paths listed from GeoNetwork's folder) to folders with new language code. (You can use any language as |
13 | | base for translation, not only English.) |
14 | | * User interface |
15 | | * 'web/geonetwork/loc/en', |
16 | | * 'web/intermap/loc/en', |
17 | | * Metadata standards |
18 | | * 'web/geonetwork/xml/schemas/dublin-core/loc/en', |
19 | | * 'web/geonetwork/xml/schemas/fgdc-std/loc/en', |
20 | | * 'web/geonetwork/xml/schemas/iso19115/loc/en', |
21 | | * 'web/geonetwork/xml/schemas/iso19139/loc/en' |
22 | | Copy also profil specific folders if you're running sandboxes like Bluenet, GéoSource or geocat.ch. |
23 | | |
24 | | Then you should change copied values with translated strings, of course. |
25 | | * In *all* files 'web/geonetwork/loc/<language code>/strings.xml' you |
26 | | should add tags with new language's code and it's name. These string |
27 | | will be used by GeoNetwork to indicate current language in language |
28 | | switcher in interface. It's a little hard to explain, look at the |
29 | | example : |
30 | | Adding Russian language identified by 'ru' in my GeoNetwork, so add string |
31 | | <ru>Русский</ru> |
32 | | in all that files, where 'ru' is Russian language code and |
33 | | 'Русский' is Russian language name on Russian. |
| 9 | * Create new record in `languages` table in your GeoNetwork's database. |
| 10 | * In all tables which name ends with `Des` copy all entries marked `en` |
| 11 | (or any other language) to entries with new language code. |
| 12 | Then you will be able to edit these fields using Web-interface. |
| 13 | * Copy folders (all paths listed from GeoNetwork's root folder) to folders |
| 14 | with new language code. (You can use any language as base for translation, not only English.) |
| 15 | User interface:: |
| 16 | * `web/geonetwork/loc/en`, |
| 17 | * `web/intermap/loc/en`. |
| 18 | Metadata standards:: |
| 19 | * `web/geonetwork/xml/schemas/dublin-core/loc/en`, |
| 20 | * `web/geonetwork/xml/schemas/fgdc-std/loc/en`, |
| 21 | * `web/geonetwork/xml/schemas/iso19115/loc/en`, |
| 22 | * `web/geonetwork/xml/schemas/iso19139/loc/en`. |
| 23 | Copy also profile specific folders if you're running sandboxes like Bluenet, GéoSource or geocat.ch. |
| 24 | Then you should change copied values with translated strings, of course. |
| 25 | * In ''all'' files `web/geonetwork/loc/`''<language code>''`/strings.xml` |
| 26 | add tags with new language's code and it's name. These string will be |
| 27 | used by GeoNetwork to indicate current language in interface switcher. |
| 28 | For example, adding Russian language identified by `ru` in GeoNetwork, |
| 29 | include into those files string `<ru>Русский</ru>`. |
| 30 | Here `ru` is the code for Russian language and `Русский` is the Russian |
| 31 | language name ''on Russian''. |
35 | | Open 'web/geonetwork/xsl/banner.xsl' for editing and find this code: |
36 | | {{{ |
37 | | <xsl:choose> |
38 | | <xsl:when test="/root/gui/language='en'"> |
39 | | <font class="banner-active"><xsl:value-of |
40 | | select="/root/gui/strings/en"/></font> |
41 | | </xsl:when> |
42 | | <xsl:otherwise> |
43 | | <a class="banner" |
44 | | href="{/root/gui/service}/en/main.home"><xsl:value-of |
45 | | select="/root/gui/strings/en"/></a> |
46 | | </xsl:otherwise> |
47 | | </xsl:choose> |
48 | | }}} |
49 | | Duplicate this fragment (separate new from old using '|') and 'en' |
50 | | to new language code. |
51 | | |
52 | | That's all! |
| 33 | Open `web/geonetwork/xsl/banner.xsl` for editing and find this code: |
| 34 | {{{ |
| 35 | <xsl:choose> |
| 36 | <xsl:when test="/root/gui/language='en'"> |
| 37 | <font class="banner-active"><xsl:value-of select="/root/gui/strings/en"/></font> |
| 38 | </xsl:when> |
| 39 | <xsl:otherwise> |
| 40 | <a class="banner" href="{/root/gui/service}/en/main.home"><xsl:value-of select="/root/gui/strings/en"/></a> |
| 41 | </xsl:otherwise> |
| 42 | </xsl:choose> |
| 43 | }}} |
| 44 | Duplicate this fragment (separating new from old using '|') and change `en` to the code of language you're adding. |
