10 | | 1. Run "ant" in the top level (no need to type "ant all", the default build does the same thing). |
11 | | 2. Change to the bin directory, start up GAST (use either gast.bat or gast.sh as appropriate for you). |
12 | | 3. In GAST, Configure your settings - at least: |
13 | | * Configuration -> Jetty: change the port number if you like and press Save |
14 | | * Configuration -> DBMS: ditto |
| 10 | 1. Run `ant` in the top level (no need to type `ant all`; the default build does the same thing). |
| 11 | 1. Change to the `bin` directory |
| 12 | 1. If you are using a recent checkout of trunk and you don't want to use the default port of 8080, edit `jetty.xml` manually, search for `8080`, and replace it with your port number of choice. |
| 13 | 1. Start up GAST (use either `gast.bat` or `gast.sh` as appropriate for you). |
| 14 | 1. In GAST, Configure your settings - at least: |
| 15 | * (If using an older version of GAST) Configuration -> Jetty: change the port number if you like and press Save |
| 16 | * Configuration -> DBMS: change the port number if you like and press Save |
16 | | * You get a warning about circular references; this is "normal". |
17 | | 4. Quit GAST. |
18 | | 5. You can now start GeoNetwork using the start-geonetwork.(sh,bat) script. |
19 | | 6. Done! Load up in your browser. |
20 | | 7. If you want to load the sample data, start up GAST again, i.e., ''after'' you started GeoNetwork, select Options from the Config menu and enter your database settings - for default !McKoi, select "Use this account" and use "admin" as username and password. Then go to Database -> Sample data and press the Import button. |
| 18 | * You may get a warning about circular references; this is "normal". |
| 19 | 1. Quit GAST. |
| 20 | 1. You can now start !GeoNetwork using the `start-geonetwork.`(`sh`,`bat`) script. |
| 21 | 1. Done! Load up in your browser. |
| 22 | 1. If you want to load the sample data, start up GAST again, i.e., ''after'' you started !GeoNetwork, select Options from the Config menu and enter your database settings - for default !McKoi, select "Use this account" and use `admin` as username and password. Then go to Database -> Sample data and press the Import button. |
