Changes between Version 3 and Version 4 of HidingMetadata
- Oct 4, 2012, 9:42:49 PM (12 years ago)
HidingMetadata
v3 v4 36 36 This proposal will modify loading metadata so that the method will do the following things: 37 37 38 * check the settings parameter hidewithheldelements if it is false then this feature is disabled38 * check the settings parameter hidewithheldelements/enabled if it is false then this feature is disabled 39 39 * check if the current user is either an administrator or the owner of the metadata if both are false then all elements will be retrieved 40 * search the document for the attribute: gco:nilReason='withheld'. if the following two checks are true then all attributes (excepting gco:nilReason) will be removed, as will all child elements. The element itself will remain as a marker 41 * Note: at the moment only gco:nilReason='withheld' attribute marks an element as hidden. In the future more tags can be added for other schema's 40 * check the settings parameter hidewithheldelements/keepMarkedElement 41 * If the value is true, then the element with the nilReason attribute will be kept. This allows the UI to display the element with a note indicating that it has been hidden 42 * If the value is false, then the element with the nilReason attribute will be kept. This allows the UI to display the element with a note indicating that it has been hidden 43 * When the marked element is kept the following happens: 44 * search the document for the attribute: gco:nilReason='withheld'. if the following two checks are true then all attributes (excepting gco:nilReason) will be removed, as will all child elements. The element itself will remain as a marker 42 45 43 By default this feature is disabled but this setting can be changed in the configuration page in administration. 46 Note: at the moment only gco:nilReason='withheld' attribute marks an element as hidden. In the future more tags can be added for other schema's. There are two places that must be updated for new takes to work with this system: 47 * the xpath in update XmlSerializer.internalSelect. 48 * Update xsl/utils.xsl by changing the hasHiddenChildren template. 49 * If the new tag is in iso19139 then the xsl:template mode="localised" match="*[@gco:nilReason='withheld'... template must be updated as well. 50 51 By default this feature is disabled but this setting can be changed in the configuration page in administration. keepMarkedElement is true by default. 44 52 45 53 In addition to hiding the metadata the Show metadata UIs will show a message that there is hidden/censored metadata. The most important use of this is to notify editors (that can't see the data) that they should not remove the element.
