Changes between Version 2 and Version 3 of HidingMetadata
- Oct 3, 2012, 8:24:08 AM (12 years ago)
HidingMetadata
v2 v3 39 39 * check if the current user is either an administrator or the owner of the metadata if both are false then all elements will be retrieved 40 40 * search the document for the attribute: gco:nilReason='withheld'. if the following two checks are true then all attributes (excepting gco:nilReason) will be removed, as will all child elements. The element itself will remain as a marker 41 * Note: at the moment only gco:nilReason='withheld' flagan element as hidden. In the future more tags can be added for other schema's41 * Note: at the moment only gco:nilReason='withheld' attribute marks an element as hidden. In the future more tags can be added for other schema's 42 42 43 43 By default this feature is disabled but this setting can be changed in the configuration page in administration.
