Changes between Version 14 and Version 15 of GeoServer_integration
- Aug 13, 2010, 9:01:30 AM (14 years ago)
v14 v15 56 56 In case of ZIP compression, ZIP file base name must be equal to Shapefile or !GeoTiff base name. 57 57 * One Datastore, !FeatureType, Layer and Style are created for a vector dataset (one to one relation). 58 * One CoverageStore, Coverage, Layer are created for a raster dataset (one to one relation).58 * One !CoverageStore, Coverage, Layer are created for a raster dataset (one to one relation). 59 59 60 60 === Other screenshots === 61 ==== With GeoServer styler installed ====61 ==== With !GeoServer styler installed ==== 62 62 [[Image(geopub-style.png)]] 63 63 … … 116 116 117 117 == Risks == 118 Due to the limited resources, complex scenario's will not be dealt with and not all data may be suitable for use. Both GeoTiff and Shapefiles require to be properly formatted before they are uploaded.118 Due to the limited resources, complex scenario's will not be dealt with and not all data may be suitable for use. Both !GeoTiff and Shapefiles require to be properly formatted before they are uploaded. 119 119 120 120 For big files (more than 100M), !OutOfMemoryError could be triggered on GeoNetwork side during file copy. Changing -Xmx and -XX:MaxPermSize parameters fixed the issue.
