Changes between Version 8 and Version 9 of ExtendedRegions
- Jan 3, 2013, 2:41:24 AM (12 years ago)
ExtendedRegions
v8 v9 6 6 || '''Status''' || Proposed || 7 7 || '''Assigned to release''' || 2.9.x || 8 || '''Resources''' || Jesse personal time||8 || '''Resources''' || Swisstopo || 9 9 || '''Code''' || https://github.com/jesseeichar/core-geonetwork/tree/improvement/regions || 10 10 … … 121 121 * geomtype - (optional) defines if geom is wkt or gml. allowed values are wkt and gml. if not specified the it is assumed the geometry is wkt 122 122 123 '''XmlSearch and CswSearch Integration''' 124 123 125 The !XmlSearch API will be modified so the geom parameter can either be WKT or have the form: region:id, where id is the id of the region to use as a geometry. If the region has a geometry then that geometry will be loaded otherwise the bbox will be used to create a polygon geometry. 124 126 … … 127 129 The actual implementation will consist of the services and a strategy object that can be configured the geonetwork configuration files. The intention is that for a particular application the strategy object can be implemented and configured for use. The default implementation will be the current implementation factored out into the strategy object. 128 130 131 '''Example URLS''' 132 * http://localhost:8080/geonetwork/srv/eng/xml.regions.category.list 133 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?categoryId=country 134 * http:/localhost:8080/geonetwork/srv/eng/xml.regions.list?categoryId=kantone 135 * http:/localhost:8080/geonetwork/srv/eng/xml.regions.list?categoryId=kantone&categoryId=country 136 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?categoryId=gemeinden 137 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?categoryId=gemeinden&maxRecords=5 138 * http://localhost:8080/geonetwork/srv/eng/xml.region.get?id=kantone:25 139 * http://localhost:8080/geonetwork/srv/eng/region.geom.wkt?id=kantone:25 140 * http://localhost:8080/geonetwork/srv/eng/region.geom.wkt?id=kantone:25&srs=EPSG:21781 141 * http://localhost:8080/geonetwork/srv/eng/region.getmap.png?id=kantone:25&height=100 142 * http://localhost:8080/geonetwork/srv/eng/region.getmap.png?id=kantone:25&srs=EPSG:21781&height=100 143 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?label=aarg 144 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?label=aarg&categoryId=kantone 145 * http://localhost:8080/geonetwork/srv/eng/xml.regions.list?label=aarg&maxRecords=5 146 129 147 === Backwards Compatibility Issues === 130 148 131 none 149 The set of regions will not be the same as for the previous versions because they will be derived from the thesaurus instead of database. 132 150 133 151 == Risks ==
