Changes between Version 36 and Version 37 of ChangesFromNGR
- 09/03/09 06:02:52 (16 years ago)
ChangesFromNGR
v36 v37 19 19 '''4.''' Service monitoring --> moved to [http://trac.osgeo.org/geonetwork/wiki/ServiceMonitoring this proposal][[BR]] 20 20 '''5.''' Tabbed view of Metadata --> moved to [http://trac.osgeo.org/geonetwork/wiki/TabbedView this proposal][[BR]] 21 '''6.''' Local rating [[BR]]21 '''6.''' Local rating --> moved to [http://trac.osgeo.org/geonetwork/wiki/LocalRating this proposal][[BR]] 22 22 '''7.''' Relevance as a percentage[[BR]] 23 23 '''8.''' Hyperlink display[[BR]] … … 78 78 79 79 '''6. Local rating'''[[BR]] 80 In !GeoNetwork, users can rate metadata. The user's rating is broadcast to all !GeoNetwork nodes known to the one where the rating happens, and the results are thus shared between nodes. In [http://nationaalgeoregister.nl NGR] this does not happen and the rating is simply kept and calculated on only the user ratings on the GN node itself. This proposal wants to make this "local" rating behaviour an option to standard !GeoNetwork, configurable through the Admin interface. 80 Moved to [http://trac.osgeo.org/geonetwork/wiki/LocalRating this proposal] 81 81 [[BR]][[BR]] 82 82
