Changes between Version 29 and Version 30 of ChangesFromNGR
08/25/09 04:31:37 (16 years ago)
thijsbrentjens
  • ChangesFromNGR
    v29 v30
    6565
    6666'''2. Persistent validation results'''[[BR]]
    67 This proposal is to run validation (XSD+Schematron) every time a metadata is inserted or changed. The result of validation is persisted in the DB. This way we can always show the current "validation status" of metadata, e.g. in the search results page.[[BR]][[BR]]
    68 Validation status is either "valid", "not valid", or "not determined". This last status is the initial validation status when validation has not yet run.[[BR]][[BR]]
    69 A validation report is also stored in the DB. It contains any XSD or schematron validation messages, a reference to the schematron file that was used, a timestamp, and if applicable a message saying that the metadata profile could not be determined.[[BR]][[BR]]
     67This proposal is to run validation (XSD+Schematron) every time a metadata is inserted or changed. The result of validation is persisted in the DB. Persistence is required to show the validation status directly (or maybe query on it later, but this is not implemented at this time). This way we can always show the current "validation status" of metadata, e.g. in the search results page.[[BR]][[BR]]
     68Validation status is either "valid", "not valid", or "not determined". This last status is the initial validation status when validation has not yet run. Currently the statuses "valid" and "not valid" are shown in the search results. Showing "not determined" as well is a minor change.[[BR]][[BR]]
     69A validation report is also stored in the DB. It contains any XSD or schematron validation messages, a reference to the schematron file that was used, a timestamp, and if applicable a message saying that the metadata profile could not be determined. There is basic support for multiple metadata profiles, using different Schematron rules for different profiles.[[BR]][[BR]]
    7070An icon indicating the validation status, that links to the validation report if the metadata is not valid, can be included in the search results page an/or in the show metadata page. This indicates something about the quality of the metadata to users, and may encourage metadata providers to produce more valid metadata.[[BR]][[BR]]
    71 TODO add screenshot
     71[[Image(ngr.validationresults.searchresults.png)]]
    7272[[BR]][[BR]]
    7373
