Changes between Version 8 and Version 9 of Bolsena2010
- Mar 26, 2010, 4:44:13 PM (14 years ago)
Bolsena2010
v8 v9 22 22 * The class {{{DataManager.java}}} and its sister {{{XMLSerializer.java}}} are in particularly bad shape, in my opinion. There are literally dozens of public methods that all do more or less the same thing. Of course it's not clearly documented why they are all there or when to use which. Would it be too drastic to propose that we keep 1 single public method for each of the functions ''createMetadata'', ''updateMetadata'', ''validateMetadata'', etc. ? 23 23 24 * Any relevant software going on that might be useful for GeoNetwork? Think of [http://mapproxy.org/ Map 24 * Any relevant software going on that might be useful for GeoNetwork? Think of [http://mapproxy.org/ MapProxy] and [http://geojquery.org/wiki/doku.php GeoJQuery]. Other ones? 25 25 26 26 * In the [http://nationaalgeoregister.nl NGR] project, a modification to the code around the editor called ''Inflation and Vacuum'' is implemented, that makes it much easier to create valid metadata from scratch. In essence it takes the function of {{{update-fixed-info.xsl}}} (which also tries to do some automatic adjustments to help things along) a whole seven miles further. What do the developers think of this? (I'll provide documentation sometime soon).
