Changes between Version 68 and Version 69 of Bolsena2010
- May 18, 2010, 4:58:44 PM (14 years ago)
Bolsena2010
v68 v69 60 60 || 38 || ||Distributed CSW search|| Distributed CSW searches are not available. Action: All OGC CSW standards and specifications should be implemented. || heikki: 1 || 61 61 || 39 || || XML validation|| Potential for remotely accessed information to be malicious. Action: !GeoNetwork should validate all XML inputs and responses (eg. as it does for CSW) and check expected MIME types e.g. you ask for a GIF, you get a GIF. And indicate / reject non-conforming content with a warning?|| heikki: 1 || 62 || 40 || ||Perfs enhancement (XSL)|| !GeoNetwork does too much expensive processing of XML documents with XSLT. Action: Continue to seek out and remove unnecessary XSLT processing.|| ||62 || 40 || ||Perfs enhancement (XSL)|| !GeoNetwork does too much expensive processing of XML documents with XSLT. Action: Continue to seek out and remove unnecessary XSLT processing.|| heikki: 4 || 63 63 || 41 || ||Configuration ||The way that !GeoNetwork handles timeouts to remote requests is not configurable. Action: In GeoNetwork, timeout on remote requests e.g. WMS, should be configurable via the administration interface.|| heikki: 2 || 64 64 || 42 || ||Project management / sandbox strategy||Developments in "sand boxes" are not pushed back into the trunk in a timely manner. Action: The PSC should publish and enforce tighter processes relating to sandboxes. If possible, all sand box developments should be pushed back into the trunk in a predetermined time period (this should be a condition of being granted permission to set up a sandbox). If the sand box feature can't be pushed into the trunk because the trunk code doesn't have the capability (e.g. Pluggable profiles, pluggable skins) then priority should be given to developing that capability in the trunk so that the sand box feature can be included into the trunk (relates to project management comment/observation above). || heikki: 1 ||
