| 124 | * !SchemaManager - redesign proposed by Mathieu: |
| 125 | * use org.geonetwork.utils.xsd.XSD in the project "geonetwork-services-ebrim" to read schemas and query contents for driving the editor |
| 126 | * GN uses a number of schemas for validation purposes eg. in OAI, could these be managed by schemamanager so that they do not need to be retrieved from net? |
| 127 | * sometimes a document may introduce a new schema eg. !ListSets response in OAI harvester can introduce the oai_dc schema eg. when harvesting jOAI - if we need to validate these responses then creating a validator with a file based schema will cause the validation to fail as the schema is not present on disk, alternative to is create a validator with no file based schema which means that all schemas will be obtained from the net but use an entityResolver object to intercept those which are local so as to avoid unnecessary retrieval or perhaps use a Java Cache System (JCS) instance to cache all schemas locally like XLinks? |
| 128 | * Multi-editing - attempting to introduce the ability to edit more than one document makes existing trunk interface confusing eg. editing documents in tabs both of which have login details. Things get out of sync - what to do? Maybe something like BlueNetMEST which is based on one window - the main search window (tabs for remote, advanced and mapviewer) with search results - editing/viewing by clicking on title opens editor/viewer in new window (multiediting is supported), clicking any of the menu options on main screen uses modalbox dialog and separate windows to keep search interface and results window untouched, log out/log in closes all editor/viewer windows to close, if editing in progress log out not allowed - this is not perfect but might be a way of thinking about how to introduce things like multiediting to trunk. |
