Changes between Initial Version and Version 1 of TracCgi
Dec 22, 2011, 1:12:39 PM (13 years ago)
  • TracCgi
     1= Installing Trac as CGI =
     3{{{
     4#!div class=important
     5  ''Please note that using Trac via CGI is the slowest deployment method available. It is slower than [TracModPython mod_python], [TracFastCgi FastCGI] and even [trac:TracOnWindowsIisAjp IIS/AJP] on Windows.''
     6}}}
     8CGI script is the entrypoint that web-server calls when a web-request to an application is made. To generate the `trac.cgi` script run:
     9{{{
     10trac-admin /path/to/env deploy /path/to/www/trac
     11}}}
     12`trac.cgi` will be in the `cgi-bin` folder inside the given path. Make sure it is executable by your web server. This command also copies `static resource` files to a `htdocs` directory of a given destination.
     13
     14== Apache web-server configuration ==
     15
     16In [http://httpd.apache.org/ Apache] there are two ways to run Trac as CGI:
     17
     18 1. Use a `ScriptAlias` directive that maps an URL to the `trac.cgi` script (recommended)
     19 2. Copy the `trac.cgi` file into the directory for CGI executables used by your web server (commonly named `cgi-bin`). You can also create a symbolic link, but in that case make sure that the `FollowSymLinks` option is enabled for the `cgi-bin` directory.
     20
     21To make Trac available at `http://yourhost.example.org/trac` add `ScriptAlias` directive to Apache configuration file, changing `trac.cgi` path to match your installation:
     22{{{
     23ScriptAlias /trac /path/to/www/trac/cgi-bin/trac.cgi
     24}}}
     25
     26 ''Note that this directive requires enabled `mod_alias` module.''
     27
     28If you're using Trac with a single project you need to set its location using the `TRAC_ENV` environment variable:
     29{{{
     30<Location "/trac">
     31  SetEnv TRAC_ENV "/path/to/projectenv"
     32</Location>
     33}}}
     34
     35Or to use multiple projects you can specify their common parent directory using the `TRAC_ENV_PARENT_DIR` variable:
     36{{{
     37<Location "/trac">
     38  SetEnv TRAC_ENV_PARENT_DIR "/path/to/project/parent/dir"
     39</Location>
     40}}}
     41
     42 ''Note that the `SetEnv` directive requires enabled `mod_env` module. It is also possible to set TRAC_ENV in trac.cgi. Just add the following code between "try:" and "from trac.web ...":''
     43
     44{{{
     45    import os
     46    os.environ['TRAC_ENV'] = "/path/to/projectenv"
     47}}}
     48
     49 '' Or for TRAC_ENV_PARENT_DIR: ''
     50
     51{{{
     52    import os
     53    os.environ['TRAC_ENV_PARENT_DIR'] = "/path/to/project/parent/dir"
     54}}}
     56If you are using the [http://httpd.apache.org/docs/suexec.html Apache suEXEC] feature please see [http://trac.edgewall.org/wiki/ApacheSuexec].
     57
     58On some systems, you ''may'' need to edit the shebang line in the `trac.cgi` file to point to your real Python installation path. On a Windows system you may need to configure Windows to know how to execute a .cgi file (Explorer -> Tools -> Folder Options -> File Types -> CGI).
     59
     60== Mapping Static Resources ==
     61
     62Out of the box, Trac will pass static resources such as style sheets or images through itself. For a CGI setup this is '''highly undesirable''', because this way CGI script is invoked for documents that could be much more efficiently served directly by web server.
     63
     64Web servers such as [http://httpd.apache.org/ Apache] allow you to create “Aliases” to resources, giving them a virtual URL that doesn't necessarily reflect the layout of the servers file system. We already used this capability by defining a `ScriptAlias` for the CGI script. We also can map requests for static resources directly to the directory on the file system, avoiding processing these requests by CGI script.
     65
     66Add the following snippet to Apache configuration '''before''' the `ScriptAlias` for the CGI script, changing paths to match your deployment:
     67{{{
     68Alias /trac/chrome/common /path/to/www/trac/htdocs
     69<Directory "/path/to/www/trac/htdocs">
     70  Order allow,deny
     71  Allow from all
     72</Directory>
     73}}}
     74
     75Note that we mapped `/trac` part of the URL to the `trac.cgi` script, and the path `/chrome/common` is the path you have to append to that location to intercept requests to the static resources.
     76
     77For example, if Trac is mapped to `/cgi-bin/trac.cgi` on your server, the URL of the Alias should be `/cgi-bin/trac.cgi/chrome/common`.
     78
     79Similarly, if you have static resources in a project's htdocs directory (which is referenced by /chrome/site URL in themes), you can configure Apache to serve those resources (again, put this '''before''' the `ScriptAlias` for the CGI script, and adjust names and locations to match your installation):
     80
     81{{{
     82Alias /trac/chrome/site /path/to/projectenv/htdocs
     83<Directory "/path/to/projectenv/htdocs">
     84  Order allow,deny
     85  Allow from all
     86</Directory>
     87}}}
     88
     89Alternatively to hacking `/trac/chrome/site`, you can directly specify path to static resources using `htdocs_location` configuration option in [wiki:TracIni trac.ini]:
     90{{{
     91[trac]
     92htdocs_location = http://yourhost.example.org/trac-htdocs
     93}}}
     94
     95Trac will then use this URL when embedding static resources into HTML pages. Of course, you still need to make the Trac `htdocs` directory available through the web server at the specified URL, for example by copying (or linking) the directory into the document root of the web server:
     96{{{
     97$ ln -s /path/to/www/trac/htdocs /var/www/yourhost.example.org/trac-htdocs
     98}}}
     100Note that in order to get this `htdocs` directory, you need first to extract the relevant Trac resources using the `deploy` command of TracAdmin:
     101[[TracAdminHelp(deploy)]]
     102
     103
     104== Adding Authentication ==
     105
     106The simplest way to enable authentication with Apache is to create a password file. Use the `htpasswd` program to create the password file:
     107{{{
     108$ htpasswd -c /somewhere/trac.htpasswd admin
     109New password: <type password>
     110Re-type new password: <type password again>
     111Adding password for user admin
     112}}}
     113
     114After the first user, you dont need the "-c" option anymore:
     115{{{
     116$ htpasswd /somewhere/trac.htpasswd john
     117New password: <type password>
     118Re-type new password: <type password again>
     119Adding password for user john
     120}}}
     121
     122  ''See the man page for `htpasswd` for full documentation.''
     123
     124After you've created the users, you can set their permissions using TracPermissions.
     125
     126Now, you'll need to enable authentication against the password file in the Apache configuration:
     127{{{
     128<Location "/trac/login">
     129  AuthType Basic
     130  AuthName "Trac"
     131  AuthUserFile /somewhere/trac.htpasswd
     132  Require valid-user
     133</Location>
     134}}}
     135
     136If you're hosting multiple projects you can use the same password file for all of them:
     137{{{
     138<LocationMatch "/trac/[^/]+/login">
     139  AuthType Basic
     140  AuthName "Trac"
     141  AuthUserFile /somewhere/trac.htpasswd
     142  Require valid-user
     143</LocationMatch>
     144}}}
     145
     146For better security, it is recommended that you either enable SSL or at least use the “digest” authentication scheme instead of “Basic”. Please read the [http://httpd.apache.org/docs/2.0/ Apache HTTPD documentation] to find out more. For example, on a Debian 4.0r1 (etch) system the relevant section  in apache configuration can look like this:
     147{{{
     148<Location "/trac/login">
     149    LoadModule auth_digest_module /usr/lib/apache2/modules/mod_auth_digest.so
     150    AuthType Digest
     151    AuthName "trac"
     152    AuthDigestDomain /trac
     153    AuthUserFile /somewhere/trac.htpasswd
     154    Require valid-user
     155</Location>
     156}}}
     157and you'll have to create your .htpasswd file with htdigest instead of htpasswd as follows:
     158{{{
     159# htdigest /somewhere/trac.htpasswd trac admin
     160}}}
     161where the "trac" parameter above is the same as !AuthName above  ("Realm" in apache-docs).
     162
     163----
     164See also:  TracGuide, TracInstall, [wiki:TracModWSGI], TracFastCgi, TracModPython
