32 | | // a function to create an argument |
33 | | gma_object_t *gma_new_object(GDALRasterBand *b, gma_class_t klass); |
34 | | |
35 | | // the next two could also be one if arg is null by default |
36 | | void gma_simple(GDALRasterBand *b, gma_method_t method); |
37 | | void gma_with_arg(GDALRasterBand *b, gma_method_with_arg_t method, gma_object_t *arg); |
38 | | |
39 | | gma_object_t *gma_compute_value(GDALRasterBand *b, gma_method_compute_value_t method, gma_object_t *arg = NULL); |
40 | | gma_object_t *gma_two_bands(GDALRasterBand *b1, gma_two_bands_method_t method, GDALRasterBand *b2, gma_object_t *arg = NULL); |
41 | | |
42 | | // errors are logged with CPLError, so the error status should be checked after every call to these functions |
43 | | |
44 | | // arguments can be created into these classes (the list is tentative) |
45 | | |
46 | | typedef enum { |
47 | | gma_number, |
48 | | gma_integer, // not a real class, used to create a number, which is integer |
49 | | gma_pair, |
50 | | gma_range, // not a real class, used to create a pair of two numbers of band datatype |
51 | | gma_bins, |
52 | | gma_histogram, |
53 | | gma_reclassifier, |
54 | | gma_cell, |
55 | | gma_logical_operation |
56 | | } gma_class_t; |
57 | | |
58 | | // the public classes contain only virtual methods |
59 | | // and they shadow the real classes which are template classes |
60 | | |
61 | | // class introspection |
62 | | // after the class is known, it is legal to cast gma_object_t* to the returned class |
63 | | virtual gma_class_t get_class() {return gma_XXX;}; |
64 | | |
65 | | // each class will have methods to build it / retrieve data from it |
66 | | |
67 | | // methods are organized into groups according to the API |
68 | | |
69 | | // these do not take any arguments and operate on the band in-place |
70 | | typedef enum { |
71 | | gma_method_print, |
72 | | gma_method_rand, |
73 | | gma_method_abs, |
74 | | gma_method_exp, |
75 | | gma_method_exp2, |
76 | | gma_method_log, |
77 | | gma_method_log2, |
78 | | gma_method_log10, |
79 | | gma_method_sqrt, |
80 | | gma_method_sin, |
81 | | gma_method_cos, |
82 | | gma_method_tan, |
83 | | gma_method_ceil, |
84 | | gma_method_floor, |
85 | | gma_method_set_border_cells |
86 | | } gma_method_t; |
87 | | |
88 | | // these take optionally an argument and compute a value from the band |
89 | | typedef enum { |
90 | | gma_method_histogram, |
91 | | gma_method_zonal_neighbors, |
92 | | gma_method_get_min, |
93 | | gma_method_get_max, |
94 | | gma_method_get_range, |
95 | | gma_method_get_cells |
96 | | } gma_method_compute_value_t; |
97 | | |
98 | | // these take an argument and operate on the band in-place |
99 | | typedef enum { |
100 | | gma_method_assign, |
101 | | gma_method_add, |
102 | | gma_method_subtract, |
103 | | gma_method_multiply, |
104 | | gma_method_divide, |
105 | | gma_method_modulus, |
106 | | gma_method_map |
107 | | } gma_method_with_arg_t; |
108 | | |
109 | | // these take an argument band and optionally another argument and operate on the band in-place |
110 | | typedef enum { |
111 | | gma_method_assign_band, |
112 | | gma_method_add_band, |
113 | | gma_method_subtract_band, |
114 | | gma_method_multiply_by_band, |
115 | | gma_method_divide_by_band, |
116 | | gma_method_modulus_by_band, |
117 | | gma_method_zonal_min, |
118 | | gma_method_zonal_max, |
119 | | gma_method_set_zonal_min, |
120 | | gma_method_rim_by8, |
121 | | gma_method_depression_pour_elevation, |
122 | | gma_method_fill_dem, |
123 | | gma_method_D8, |
124 | | gma_method_route_flats, |
125 | | gma_method_depressions, |
126 | | gma_method_upstream_area, |
127 | | gma_method_catchment |
128 | | } gma_two_bands_method_t; |
| 32 | // The C++ API (these are all interface classes, so everything is virtual as the actual code is in hidden template classes |
| 33 | |
| 34 | class gma_object_t { |
| 35 | public: |
| 36 | virtual ~gma_object_t() {}; |
| 37 | virtual gma_class_t get_class() {return gma_object;}; |
| 38 | virtual gma_object_t *clone() {}; |
| 39 | }; |
| 40 | |
| 41 | class gma_number_t : public gma_object_t { |
| 42 | public: |
| 43 | virtual gma_class_t get_class() {return gma_number;}; |
| 44 | virtual void set_value(double value) {}; |
| 45 | virtual void set_value(int value) {}; |
| 46 | virtual int value_as_int() {}; |
| 47 | virtual double value_as_double() {}; |
| 48 | virtual gma_number_t *clone() {}; |
| 49 | virtual void set_inf(int inf) {}; // -1 to minus inf, 0 to not inf, 1 to plus inf |
| 50 | virtual bool is_inf() {}; |
| 51 | virtual bool is_integer() {}; |
| 52 | virtual bool is_float() {}; |
| 53 | }; |
| 54 | |
| 55 | class gma_pair_t : public gma_object_t { |
| 56 | public: |
| 57 | virtual gma_class_t get_class() {return gma_pair;}; |
| 58 | virtual void set_first(gma_object_t *first) {}; |
| 59 | virtual void set_second(gma_object_t *second) {}; |
| 60 | virtual gma_object_t *first() {}; |
| 61 | virtual gma_object_t *second() {}; |
| 62 | }; |
| 63 | |
| 64 | class gma_bins_t : public gma_object_t { |
| 65 | public: |
| 66 | virtual gma_class_t get_class() {return gma_bins;}; |
| 67 | virtual unsigned int size() {}; |
| 68 | virtual void push(int value) {}; |
| 69 | virtual void push(double value) {}; |
| 70 | }; |
| 71 | |
| 72 | class gma_histogram_t : public gma_object_t { |
| 73 | public: |
| 74 | virtual gma_class_t get_class() {return gma_histogram;}; |
| 75 | virtual unsigned int size() {}; |
| 76 | virtual gma_object_t *at(unsigned int i) {}; |
| 77 | }; |
| 78 | |
| 79 | class gma_classifier_t : public gma_object_t { |
| 80 | public: |
| 81 | virtual gma_class_t get_class() {return gma_classifier;}; |
| 82 | virtual void add_class(gma_number_t *interval_max, gma_number_t *value) {}; |
| 83 | virtual unsigned int size() {}; |
| 84 | virtual gma_object_t *at(unsigned int i) {}; |
| 85 | }; |
| 86 | |
| 87 | class gma_cell_t : public gma_object_t { |
| 88 | public: |
| 89 | virtual gma_class_t get_class() {return gma_cell;}; |
| 90 | virtual int& x() {}; |
| 91 | virtual int& y() {}; |
| 92 | virtual void set_value(double value) {}; |
| 93 | virtual void set_value(int value) {}; |
| 94 | virtual int value_as_int() {}; |
| 95 | virtual double value_as_double() {}; |
| 96 | }; |
| 97 | |
| 98 | /* |
| 99 | Return value 0 interrupts, 1 denotes ok, and 2 denotes ok and a need |
| 100 | to save the cell value back to band. |
| 101 | */ |
| 102 | typedef int (*gma_cell_callback_f)(gma_cell_t*, gma_object_t*); |
| 103 | |
| 104 | class gma_cell_callback_t : public gma_object_t { |
| 105 | public: |
| 106 | virtual gma_class_t get_class() {return gma_cell_callback;}; |
| 107 | virtual void set_callback(gma_cell_callback_f callback) {}; |
| 108 | virtual void set_user_data(gma_object_t*) {}; |
| 109 | }; |
| 110 | |
| 111 | class gma_logical_operation_t : public gma_object_t { |
| 112 | public: |
| 113 | virtual gma_class_t get_class() {return gma_logical_operation;}; |
| 114 | virtual void set_operation(gma_operator_t) {}; |
| 115 | virtual void set_value(int value) {}; |
| 116 | virtual void set_value(double value) {}; |
| 117 | }; |
| 118 | |
| 119 | class gma_hash_t : public gma_object_t { |
| 120 | public: |
| 121 | virtual gma_class_t get_class() {return gma_hash;}; |
| 122 | virtual int size() {}; |
| 123 | virtual std::vector<gma_number_t*> *keys_sorted() {}; |
| 124 | virtual gma_object_t *get(gma_number_t *key) {}; |
| 125 | }; |
| 126 | |
| 127 | class gma_band_t : public gma_object_t { |
| 128 | public: |
| 129 | virtual gma_class_t get_class() {return gma_band;}; |
| 130 | virtual GDALDataType gdal_datatype() {}; |
| 131 | virtual gma_number_t *new_number(int value) {}; |
| 132 | |
| 133 | virtual void print() {}; |
| 134 | virtual void rand() {}; |
| 135 | virtual void abs() {}; |
| 136 | virtual void exp() {}; |
| 137 | virtual void log() {}; |
| 138 | virtual void log10() {}; |
| 139 | virtual void sqrt() {}; |
| 140 | virtual void sin() {}; |
| 141 | virtual void cos() {}; |
| 142 | virtual void tan() {}; |
| 143 | virtual void ceil() {}; |
| 144 | virtual void floor() {}; |
| 145 | |
| 146 | virtual void assign(int value) {}; |
| 147 | virtual void assign_all(int value) {}; |
| 148 | virtual void add(int summand) {}; |
| 149 | virtual void subtract(int) {}; |
| 150 | virtual void multiply(int) {}; |
| 151 | virtual void divide(int) {}; |
| 152 | virtual void modulus(int divisor) {}; |
| 153 | |
| 154 | virtual void assign(double value) {}; |
| 155 | virtual void assign_all(double value) {}; |
| 156 | virtual void add(double summand) {}; |
| 157 | virtual void subtract(double) {}; |
| 158 | virtual void multiply(double) {}; |
| 159 | virtual void divide(double) {}; |
| 160 | |
| 161 | virtual void classify(gma_classifier_t*) {}; |
| 162 | virtual void cell_callback(gma_cell_callback_t*) {}; |
| 163 | |
| 164 | // arg = NULL, pair:(n,pair:(min,max)), or bins; returns histogram |
| 165 | virtual gma_histogram_t *histogram(gma_object_t *arg = NULL) {}; |
| 166 | // returns hash of a hashes, keys are zone numbers |
| 167 | virtual gma_hash_t *zonal_neighbors() {}; |
| 168 | virtual gma_number_t *get_min() {}; |
| 169 | virtual gma_number_t *get_max() {}; |
| 170 | // returns a pair of numbers |
| 171 | virtual gma_pair_t *get_range() {}; |
| 172 | virtual std::vector<gma_cell_t*> *gma_method_get_cells() {}; |
| 173 | |
| 174 | virtual void assign(gma_band_t *) {}; |
| 175 | virtual void add(gma_band_t *summand) {}; |
| 176 | virtual void subtract(gma_band_t *) {}; |
| 177 | virtual void multiply(gma_band_t *) {}; |
| 178 | virtual void divide(gma_band_t *) {}; |
| 179 | virtual void modulus(gma_band_t *) {}; |
| 180 | |
| 181 | virtual gma_hash_t *zonal_min(gma_band_t *zones) {}; |
| 182 | virtual gma_hash_t *zonal_max(gma_band_t *zones) {}; |
| 183 | |
| 184 | virtual void rim_by8(gma_band_t *areas) {}; |
| 185 | |
| 186 | virtual void fill_depressions(gma_band_t *dem) {}; |
| 187 | virtual void D8(gma_band_t *dem) {}; |
| 188 | virtual void route_flats(gma_band_t *dem) {}; |
| 189 | virtual void upstream_area(gma_band_t *) {}; |
| 190 | virtual void catchment(gma_band_t *, gma_cell_t *) {}; |
| 191 | |
| 192 | }; |
