Changes between Version 23 and Version 24 of rfc61_support_for_measured_geometries
- Jan 29, 2016, 2:28:38 AM (8 years ago)
v23 v24 141 141 Add property double m to class OGRPoint. Add constructor, getters, and setters for it. 142 142 143 Add property double *padfM to class OGRSimpleCurve. Add constructor, getters, and setters for it. The getters and setters can take advantage of the flags to determine whether Z or M is to be set in some of them - this is needed for prototypes like set(double, double, double). For backwards compatibility Z is preferred.143 Add property double *padfM to class OGRSimpleCurve. Add constructor, getters, and setters for it. New setters with postfix M are needed for XYM data since the object may be upgraded to XYZ from XY in setters. 144 144 145 145 Override methods set3D and setMeasured in those classes where setCoordinateDimension is overridden.
