| 1 | = RFC 61 : Support for measured geometries = |
| 2 | |
| 3 | Author: Ari Jolma[[BR]] |
| 4 | |
| 5 | Contact: ari.jolma at gmail.com[[BR]] |
| 6 | |
| 7 | Status: Draft[[BR]] |
| 8 | |
| 9 | Implementation version: 2.1 or 2.2 |
| 10 | |
| 11 | == Summary == |
| 12 | |
| 13 | This RFC defines how to implement measured geometries (geometries, where the points have M coordinate, i.e., they are XYM or XYZM). |
| 14 | |
| 15 | == Rationale == |
| 16 | |
| 17 | M coordinate is in the OGC simple feature model and it is used in many vector data formats. |
| 18 | |
| 19 | == Changes == |
| 20 | |
| 21 | Changes are required into the C++ API and the C API needs to be enhanced. Several drivers need to be changed to take advantage of this enhancement but also due to the changes in the C++ API. |
| 22 | |
| 23 | === Common API === |
| 24 | |
| 25 | ogr_core.h: |
| 26 | {{{ |
| 27 | #define OGR_G_NOT_EMPTY 1 |
| 28 | #define OGR_G_3D 3 |
| 29 | #define OGR_G_MEASURED 5 |
| 30 | }}} |
| 31 | |
| 32 | New OGRwkbGeometryType values are needed - that is rather complex system now due to history. |
| 33 | |
| 34 | === C++ API === |
| 35 | |
| 36 | Change int nCoordDimension to int flags, which is used to keep track of whether the geometry is empty (currently hacks such as nCoordDimension == -2 is used for that), has Z, or is measured. IsEmpty = flags & ~OGR_G_NOT_EMPTY, Is3D = flags & OGR_G_3D, IsMeasured = flags & OGR_G_MEASURED. |
| 37 | |
| 38 | Keep, but deprecate |
| 39 | {{{ |
| 40 | getCoordinateDimension(); |
| 41 | setCoordinateDimension(); |
| 42 | }}} |
| 43 | |
| 44 | class OGRGeometry: |
| 45 | {{{ |
| 46 | //Add methods: |
| 47 | int CoordinateDimension(); |
| 48 | OGRBoolean Is3D(); |
| 49 | OGRBoolean IsMeasured(); |
| 50 | virtual void set3D(OGRBoolean bIs3D); |
| 51 | virtual void setMeasured(OGRBoolean bIsMeasured); |
| 52 | |
| 53 | //Add now or later methods: |
| 54 | virtual OGRGeometry *LocateAlong(double mValue); |
| 55 | virtual OGRGeometry *LocateBetween(double mStart, double mEnd); |
| 56 | }}} |
| 57 | |
| 58 | Add property double m to class OGRPoint. Add constructor, getters, and setters for it. |
| 59 | |
| 60 | Add property double *padfM to class OGRSimpleCurce. Add constructor, getters, and setters for it. The getters and setters can take advantage of the flags to determine whether Z or M is to be set in some of them. For backwards compatibility Z is preferred. |
| 61 | |
| 62 | Override methods set3D and setMeasured in those classes where setCoordinateDimension is overridden. |
| 63 | |
| 64 | === C API === |
| 65 | |
| 66 | ogr_core.h: |
| 67 | {{{ |
| 68 | OGRwkbGeometryType CPL_DLL OGR_GT_SetM( OGRwkbGeometryType eType ); |
| 69 | int CPL_DLL OGR_GT_HasM( OGRwkbGeometryType eType ); |
| 70 | }}} |
| 71 | ogr_api.h: (new versions of some functions are needed, use postfix M) |
| 72 | {{{ |
| 73 | void CPL_DLL OGR_G_Is3D( OGRGeometryH ); |
| 74 | void CPL_DLL OGR_G_IsMeasured( OGRGeometryH ); |
| 75 | |
| 76 | void CPL_DLL OGR_G_Set3D( OGRGeometryH, int ); |
| 77 | void CPL_DLL OGR_G_SetMeasured( OGRGeometryH, int ); |
| 78 | |
| 79 | int CPL_DLL OGR_G_GetPointsM( OGRGeometryH hGeom, |
| 80 | void* pabyX, int nXStride, |
| 81 | void* pabyY, int nYStride, |
| 82 | void* pabyZ, int nZStride, |
| 83 | void* pabyM, int nMStride); |
| 84 | double CPL_DLL OGR_G_GetM( OGRGeometryH, int ); |
| 85 | void CPL_DLL OGR_G_GetPointM( OGRGeometryH, int iPoint, |
| 86 | double *, double *, double *, double * ); |
| 87 | void CPL_DLL OGR_G_SetPointM( OGRGeometryH, int iPoint, |
| 88 | double, double, double, double ); |
| 89 | void CPL_DLL OGR_G_AddPointM( OGRGeometryH, double, double, double, double ); |
| 90 | void CPL_DLL OGR_G_SetPointsM( OGRGeometryH hGeom, int nPointsIn, |
| 91 | void* pabyX, int nXStride, |
| 92 | void* pabyY, int nYStride, |
| 93 | void* pabyZ, int nZStride, |
| 94 | void* pabyM, int nMStride ); |
| 95 | |
| 96 | }}} |
| 97 | |
| 98 | ogr_p.g |
| 99 | {{{ |
| 100 | const char CPL_DLL * OGRWktReadPointsM( const char * pszInput, |
| 101 | OGRRawPoint **ppaoPoints, |
| 102 | double **ppadfZ, |
| 103 | double **ppadfM, |
| 104 | int * pnMaxPoints, |
| 105 | int * pnReadPoints ); |
| 106 | void CPL_DLL OGRMakeWktCoordinateM( char *, double, double, double, double, int ); |
| 107 | |
| 108 | }}} |
| 109 | |
| 110 | pggeometry.h is internal, so we can change the function prototype |
| 111 | {{{ |
| 112 | void OGRCreateFromMultiPatchPart(OGRMultiPolygon *poMP, |
| 113 | OGRPolygon*& poLastPoly, |
| 114 | int nPartType, |
| 115 | int nPartPoints, |
| 116 | double* padfX, |
| 117 | double* padfY, |
| 118 | double* padfZ, |
| 119 | double* padfM); |
| 120 | }}} |
| 121 | |
| 122 | |
| 123 | == SWIG bindings (Python / Java / C# / Perl) changes == |
| 124 | |
| 125 | The new C API functions need to be exposed through swig. Further changes depend on whether the language bindings are aware of coordinates. At least Python and Perl are. |
| 126 | |
| 127 | == Drivers == |
| 128 | |
| 129 | Drivers that are probably affected by the C++ changes are at least (these use the CoordinateDimension API) pg, mssqlspatial, sqlite, db2, mysql, gml, pgdump, geojson, libkml, gpkg, wasp, gpx, filegdb, vfk, bna, dxf. |
| 130 | |
| 131 | |
| 132 | == Utilities == |
| 133 | |
| 134 | to do |
| 135 | |
| 136 | == Documentation == |
| 137 | |
| 138 | All new methods/functions are documented. |
| 139 | |
| 140 | == Test Suite == |
| 141 | |
| 142 | to do |
| 143 | |
| 144 | == Compatibility Issues == |
| 145 | |
| 146 | to do |
| 147 | |
| 148 | == Related tickets == |
| 149 | |
| 150 | https://trac.osgeo.org/gdal/ticket/6063 |
| 151 | https://trac.osgeo.org/gdal/ticket/6331 |
| 152 | |
| 153 | == Implementation == |
| 154 | |
| 155 | The implementation will be done by Ari Jolma. |
| 156 | |
| 157 | The proposed implementation will be in https://github.com/ajolma/GDAL-XYZM |
| 158 | |
| 159 | == Voting history |
