Changes between Version 10 and Version 11 of rfc45_virtualmem
- May 7, 2014, 3:47:32 AM (10 years ago)
rfc45_virtualmem
v10 v11 181 181 * @return the page size. 182 182 * 183 * @since GDAL 2.0183 * @since GDAL 1.11 184 184 */ 185 185 size_t CPL_DLL CPLGetPageSize(void); … … 226 226 * or NULL in case of failure. 227 227 * 228 * @since GDAL 2.0228 * @since GDAL 1.11 229 229 */ 230 230 … … 243 243 * 244 244 * @return TRUE if virtual memory mapping of a file is available. 245 * @since GDAL 2.0245 * @since GDAL 1.11 246 246 */ 247 247 int CPL_DLL CPLIsVirtualMemFileMapAvailable(void); … … 270 270 * or NULL in case of failure. 271 271 * 272 * @since GDAL 2.0272 * @since GDAL 1.11 273 273 */ 274 274 CPLVirtualMem CPL_DLL *CPLVirtualMemFileMapNew( VSILFILE* fp, … … 296 296 * or NULL in case of failure. 297 297 * 298 * @since GDAL 2.0298 * @since GDAL 1.11 299 299 */ 300 300 CPLVirtualMem CPL_DLL *CPLVirtualMemDerivedNew(CPLVirtualMem* pVMemBase, … … 313 313 * @param ctxt context returned by CPLVirtualMemNew(). 314 314 * 315 * @since GDAL 2.0315 * @since GDAL 1.11 316 316 */ 317 317 void CPL_DLL CPLVirtualMemFree(CPLVirtualMem* ctxt); … … 330 330 * @return the pointer to the start of a virtual memory mapping. 331 331 * 332 * @since GDAL 2.0332 * @since GDAL 1.11 333 333 */ 334 334 void CPL_DLL *CPLVirtualMemGetAddr(CPLVirtualMem* ctxt); … … 339 339 * @return the size of the virtual memory mapping. 340 340 * 341 * @since GDAL 2.0341 * @since GDAL 1.11 342 342 */ 343 343 size_t CPL_DLL CPLVirtualMemGetSize(CPLVirtualMem* ctxt); … … 348 348 * @return TRUE if the virtal memory mapping is a direct file mapping. 349 349 * 350 * @since GDAL 2.0350 * @since GDAL 1.11 351 351 */ 352 352 int CPL_DLL CPLVirtualMemIsFileMapping(CPLVirtualMem* ctxt); … … 357 357 * @return the access mode of the virtual memory mapping. 358 358 * 359 * @since GDAL 2.0359 * @since GDAL 1.11 360 360 */ 361 361 CPLVirtualMemAccessMode CPL_DLL CPLVirtualMemGetAccessMode(CPLVirtualMem* ctxt); … … 369 369 * @return the page size 370 370 * 371 * @since GDAL 2.0371 * @since GDAL 1.11 372 372 */ 373 373 size_t CPL_DLL CPLVirtualMemGetPageSize(CPLVirtualMem* ctxt); … … 388 388 * threads. 389 389 * 390 * @since GDAL 2.0390 * @since GDAL 1.11 391 391 */ 392 392 int CPL_DLL CPLVirtualMemIsAccessThreadSafe(CPLVirtualMem* ctxt); … … 402 402 * @param ctxt context returned by CPLVirtualMemNew(). 403 403 * 404 * @since GDAL 2.0404 * @since GDAL 1.11 405 405 */ 406 406 void CPL_DLL CPLVirtualMemDeclareThread(CPLVirtualMem* ctxt); … … 416 416 * @param ctxt context returned by CPLVirtualMemNew(). 417 417 * 418 * @since GDAL 2.0418 * @since GDAL 1.11 419 419 */ 420 420 void CPL_DLL CPLVirtualMemUnDeclareThread(CPLVirtualMem* ctxt); … … 435 435 * @param bWriteOp set to TRUE if the memory are will be accessed in write mode. 436 436 * 437 * @since GDAL 2.0437 * @since GDAL 1.11 438 438 */ 439 439 void CPL_DLL CPLVirtualMemPin(CPLVirtualMem* ctxt, … … 445 445 * been freed. 446 446 * 447 * @since GDAL 2.0447 * @since GDAL 1.11 448 448 */ 449 449 void CPL_DLL CPLVirtualMemManagerTerminate(void); … … 564 564 * or NULL in case of failure. 565 565 * 566 * @since GDAL 2.0566 * @since GDAL 1.11 567 567 */ 568 568 … … 676 676 * or NULL in case of failure. 677 677 * 678 * @since GDAL 2.0678 * @since GDAL 1.11 679 679 */ 680 680 … … 803 803 * or NULL in case of failure. 804 804 * 805 * @since GDAL 2.0805 * @since GDAL 1.11 806 806 */ 807 807 … … 903 903 * or NULL in case of failure. 904 904 * 905 * @since GDAL 2.0905 * @since GDAL 1.11 906 906 */ 907 907 … … 975 975 * or NULL in case of failure. 976 976 * 977 * @since GDAL 2.0977 * @since GDAL 1.11 978 978 */ 979 979
