| 1 | = RFC 45: GDAL datasets and raster bands as virtual memory objects = |
| 2 | |
| 3 | Authors: Even Rouault[[BR]] |
| 4 | Contact: even dot rouault at mines dash paris dot org[[BR]] |
| 5 | Status: Developement |
| 6 | |
| 7 | == Summary == |
| 8 | |
| 9 | This document proposes additions to GDAL so that image data of GDAL datasets and |
| 10 | raster bands can be seen as virtual memory objects, for hopefully simpler usage. |
| 11 | |
| 12 | == Rationale == |
| 13 | |
| 14 | When one wants to read or write image data from/into a GDAL dataset or raster |
| 15 | band, one must use the RasterIO() interface for the regions of interest that |
| 16 | are read or written. For small images, the most convenient solution is usually |
| 17 | to read/write the whole image in a single request where the region of interest |
| 18 | is the full raster extent. For larger images, particularly when they do not |
| 19 | fit entirely in RAM, this is not possible, and if one wants to operate on the |
| 20 | whole image, one must use a windowing strategy to avoid memory issues : typically |
| 21 | by proceeding scanline (or group of scanlines) by scanline, or by blocks for tiled |
| 22 | images. This can make the writing of algorithms more complicated when they need |
| 23 | to access a neighbourhoud of pixels around each pixel of interest, since the size of this |
| 24 | extra window must be taken into account, leading to overlapping regions of |
| 25 | interests. Nothing that cannot be solved, but that requires some additional |
| 26 | thinking that distracts from the followed main purpose. |
| 27 | |
| 28 | The proposed addition of this RFC is to make the image data appear as a single |
| 29 | array accessed with a pointer, without being limited by the size of RAM with |
| 30 | respect to the size of the dataset (excepted limitations imposed by the CPU |
| 31 | architecture and the operating system) |
| 32 | |
| 33 | === Technical solution === |
| 34 | |
| 35 | ==== Low-level machinery : cpl_virtualmem.h ==== |
| 36 | |
| 37 | The low-level machinery to support this new capability is a CPLVirtualMem object |
| 38 | that represents an area of virtual memory ( on Linux, an area of virtual memory |
| 39 | allocated by the mmap() function ). This virtual memory area is initially just |
| 40 | reserved in terms of virtual memory space, but has no actual allocation in |
| 41 | physical memory. This reserved virtual memory space is protected with an access |
| 42 | permission that cause any attempt to access it to result in an exception - a |
| 43 | page fault, that on POSIX systems triggers a SIGSEGV signal (segmentation fault). |
| 44 | Fortunately, segmentation faults can be caught by the software with a signal |
| 45 | handler. When such a segmentation fault occurs, our specialized signal handler |
| 46 | will check if it occurs in a virtual memory region under its responsibility and, |
| 47 | if so, it will proceed to fill the part (a "page") of the virtual memory area |
| 48 | that has been accessed with sensible values (thanks to a user provided callback). |
| 49 | It will then set appropriate permissions to the page (read-only or read-write), |
| 50 | before attempting again the instruction that triggered the segmentation fault. |
| 51 | From the point of view of the user code that accesses the memory mapping, this |
| 52 | is completely transparent, and this is equivalent as if the whole virtual memory |
| 53 | area had been filled from the start. |
| 54 | |
| 55 | For very large mappings that are larger than RAM, this would still cause disk |
| 56 | swapping to occur at a certain point. To avoid that, the segmentation fault |
| 57 | handler will evict the least recently used pages, once a threshold defined at the |
| 58 | creation of the CPLVirtualMem object has been reached. |
| 59 | |
| 60 | For write support, another callback can be passed. It will be called before a |
| 61 | page is evicted so that user code has a chance to flush its content to a more |
| 62 | persistent storage. |
| 63 | |
| 64 | ==== High-level usage ==== |
| 65 | |
| 66 | Four new API are introduced (detailed in further section): |
| 67 | |
| 68 | * GDALDatasetGetVirtualMem() : takes almost the same arguments as GDALDatasetRasterIO(), with the notable exception of a pData buffer. It returns a CPLVirtualMem* object, from which the base address of the virtual memory mapping can be obtained with CPLVirtualMemGetAddr(). |
| 69 | |
| 70 | * GDALRasterBandGetVirtualMem(): equivalent of GDALDatasetGetVirtualMem() that operates on a raster band object rather than a dataset object. |
| 71 | |
| 72 | * GDALDatasetGetTiledVirtualMem(): this is a rather original API. Instead of presenting a 2D view of the image data (i.e. organized rows by rows), the mapping exposes it as an array of tiles, which is more suitable, performance wise, when the dataset is itself tiled. |
| 73 | |
| 74 | [ INSERT SCHEMA HERE ] |
| 75 | |
| 76 | When they are several bands, 3 different organizations of band components are possible. To the best of our knowledge, there is no standard way of calling those organizations, which consequently will be best illustrated by the folowing schemas : |
| 77 | |
| 78 | [ INSERT SCHEMAS HERE ] |
| 79 | |
| 80 | * GDALRasterBandGetTiledVirtualMem(): equivalent of GDALDatasetGetTiledVirtualMem() that operates on a raster band object rather than a dataset object. |
| 81 | |
| 82 | == Details of new API == |
| 83 | |
| 84 | === Implemented by cpl_virtualmem.cpp === |
| 85 | |
| 86 | {{{ |
| 87 | |
| 88 | /** |
| 89 | * \file cpl_virtualmem.h |
| 90 | * |
| 91 | * Virtual memory management. |
| 92 | * |
| 93 | * This file provides mechanism to define virtual memory mappings, whose content |
| 94 | * is allocated transparently and filled on-the-fly. Those virtual memory mappings |
| 95 | * can be much larger than the available RAM, but only parts of the virtual |
| 96 | * memory mapping, in the limit of the allowed the cache size, will actually be |
| 97 | * physically allocated. |
| 98 | * |
| 99 | * This exploits low-level mechanisms of the operating system (virtual memory |
| 100 | * allocation, page protection and handler of virtual memory exceptions). |
| 101 | * |
| 102 | * The current implementation is Linux only. |
| 103 | */ |
| 104 | |
| 105 | /** Opaque type that represents a virtual memory mapping. */ |
| 106 | typedef struct CPLVirtualMem CPLVirtualMem; |
| 107 | |
| 108 | /** Callback triggered when a still unmapped page of virtual memory is accessed. |
| 109 | * The callback has the responsibility of filling the page with relevant values |
| 110 | * |
| 111 | * @param ctxt virtual memory handle. |
| 112 | * @param nOffset offset of the page in the memory mapping. |
| 113 | * @param pPageToFill address of the page to fill. Note that the address might |
| 114 | * be a temporary location, and not at CPLVirtualMemGetAddr() + nOffset. |
| 115 | * @param nToFill number of bytes of the page. |
| 116 | * @param pUserData user data that was passed to CPLVirtualMemNew(). |
| 117 | */ |
| 118 | typedef void (*CPLVirtualMemCachePageCbk)(CPLVirtualMem* ctxt, |
| 119 | size_t nOffset, |
| 120 | void* pPageToFill, |
| 121 | size_t nToFill, |
| 122 | void* pUserData); |
| 123 | |
| 124 | /** Callback triggered when a dirty mapped page is going to be freed. |
| 125 | * (saturation of cache, or termination of the virtual memory mapping). |
| 126 | * |
| 127 | * @param ctxt virtual memory handle. |
| 128 | * @param nOffset offset of the page in the memory mapping. |
| 129 | * @param pPageToBeEvicted address of the page that will be flushed. Note that the address might |
| 130 | * be a temporary location, and not at CPLVirtualMemGetAddr() + nOffset. |
| 131 | * @param nToBeEvicted number of bytes of the page. |
| 132 | * @param pUserData user data that was passed to CPLVirtualMemNew(). |
| 133 | */ |
| 134 | typedef void (*CPLVirtualMemUnCachePageCbk)(CPLVirtualMem* ctxt, |
| 135 | size_t nOffset, |
| 136 | const void* pPageToBeEvicted, |
| 137 | size_t nToBeEvicted, |
| 138 | void* pUserData); |
| 139 | |
| 140 | typedef void (*CPLVirtualMemFreeUserData)(void* pUserData); |
| 141 | |
| 142 | /** Access mode of a virtual memory mapping. */ |
| 143 | typedef enum |
| 144 | { |
| 145 | /*! The mapping is meant at being read-only, but writes will not be prevented. |
| 146 | Note that any content written will be lost. */ |
| 147 | VIRTUALMEM_READONLY, |
| 148 | /*! The mapping is meant at being read-only, and this will be enforced |
| 149 | through the operating system page protection mechanism. */ |
| 150 | VIRTUALMEM_READONLY_ENFORCED, |
| 151 | /*! The mapping is meant at being read-write, and modified pages can be saved |
| 152 | thanks to the pfnUnCachePage callback */ |
| 153 | VIRTUALMEM_READWRITE |
| 154 | } CPLVirtualMemAccessMode; |
| 155 | |
| 156 | |
| 157 | /** Return the size of a page of virtual memory. |
| 158 | * |
| 159 | * @return the page size. |
| 160 | * |
| 161 | * @since GDAL 2.0 |
| 162 | */ |
| 163 | size_t CPL_DLL CPLGetPageSize(void); |
| 164 | |
| 165 | /** Create a new virtual memory mapping. |
| 166 | * |
| 167 | * This will reserve an area of virtual memory of size nSize, whose size |
| 168 | * might be potentially much larger than the physical memory available. Initially, |
| 169 | * no physical memory will be allocated. As soon as memory pages will be accessed, |
| 170 | * they will be allocated transparently and filled with the pfnCachePage callback. |
| 171 | * When the allowed cache size is reached, the least recently used pages will |
| 172 | * be unallocated. |
| 173 | * |
| 174 | * On Linux AMD64 platforms, the maximum value for nSize is 128 TB. |
| 175 | * On Linux x86 platforms, the maximum value for nSize is 2 GB. |
| 176 | * |
| 177 | * Only supported on Linux for now. |
| 178 | * |
| 179 | * Note that on Linux, this function will install a SIGSEGV handler. The |
| 180 | * original handler will be restored by CPLVirtualMemManagerTerminate(). |
| 181 | * |
| 182 | * @param nSize size in bytes of the virtual memory mapping. |
| 183 | * @param nCacheSize size in bytes of the maximum memory that will be really |
| 184 | * allocated (must ideally fit into RAM). |
| 185 | * @param nPageSizeHint hint for the page size. Must be a multiple of the |
| 186 | * system page size, returned by CPLGetPageSize(). |
| 187 | * Minimum value is generally 4096. Might be set to 0 to |
| 188 | * let the function determine a default page size. |
| 189 | * @param bSingleThreadUsage set to TRUE if there will be no concurrent threads |
| 190 | * that will access the virtual memory mapping. This can |
| 191 | * optimize performance a bit. |
| 192 | * @param eAccessMode permission to use for the virtual memory mapping. |
| 193 | * @param pfnCachePage callback triggered when a still unmapped page of virtual |
| 194 | * memory is accessed. The callback has the responsibility |
| 195 | * of filling the page with relevant values. |
| 196 | * @param pfnUnCachePage callback triggered when a dirty mapped page is going to |
| 197 | * be freed (saturation of cache, or termination of the |
| 198 | * virtual memory mapping). Might be NULL. |
| 199 | * @param pfnFreeUserData callback that can be used to free pCbkUserData. Might be |
| 200 | * NULL |
| 201 | * @param pCbkUserData user data passed to pfnCachePage and pfnUnCachePage. |
| 202 | * |
| 203 | * @return a virtual memory object that must be freed by CPLVirtualMemFree(), |
| 204 | * or NULL in case of failure. |
| 205 | * |
| 206 | * @since GDAL 2.0 |
| 207 | */ |
| 208 | |
| 209 | CPLVirtualMem CPL_DLL *CPLVirtualMemNew(size_t nSize, |
| 210 | size_t nCacheSize, |
| 211 | size_t nPageSizeHint, |
| 212 | int bSingleThreadUsage, |
| 213 | CPLVirtualMemAccessMode eAccessMode, |
| 214 | CPLVirtualMemCachePageCbk pfnCachePage, |
| 215 | CPLVirtualMemUnCachePageCbk pfnUnCachePage, |
| 216 | CPLVirtualMemFreeUserData pfnFreeUserData, |
| 217 | void *pCbkUserData); |
| 218 | |
| 219 | /** Free a virtual memory mapping. |
| 220 | * |
| 221 | * The pointer returned by CPLVirtualMemGetAddr() will no longer be valid. |
| 222 | * If the virtual memory mapping was created with read/write permissions and that |
| 223 | * they are dirty (i.e. modified) pages, they will be flushed through the |
| 224 | * pfnUnCachePage callback before being freed. |
| 225 | * |
| 226 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 227 | * |
| 228 | * @since GDAL 2.0 |
| 229 | */ |
| 230 | void CPL_DLL CPLVirtualMemFree(CPLVirtualMem* ctxt); |
| 231 | |
| 232 | /** Return the pointer to the start of a virtual memory mapping. |
| 233 | * |
| 234 | * The bytes in the range [p:p+CPLVirtualMemGetSize()-1] where p is the pointer |
| 235 | * returned by this function will be valid, until CPLVirtualMemFree() is called. |
| 236 | * |
| 237 | * Note that if a range of bytes used as an argument of a system call |
| 238 | * (such as read() or write()) contains pages that have not been "realized", the |
| 239 | * system call will fail with EFAULT. CPLVirtualMemPin() can be used to work |
| 240 | * around this issue. |
| 241 | * |
| 242 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 243 | * @return the pointer to the start of a virtual memory mapping. |
| 244 | * |
| 245 | * @since GDAL 2.0 |
| 246 | */ |
| 247 | void CPL_DLL *CPLVirtualMemGetAddr(CPLVirtualMem* ctxt); |
| 248 | |
| 249 | /** Return the size of the virtual memory mapping. |
| 250 | * |
| 251 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 252 | * @return the size of the virtual memory mapping. |
| 253 | * |
| 254 | * @since GDAL 2.0 |
| 255 | */ |
| 256 | size_t CPL_DLL CPLVirtualMemGetSize(CPLVirtualMem* ctxt); |
| 257 | |
| 258 | /** Return the page size associated to a virtual memory mapping. |
| 259 | * |
| 260 | * The value returned will be at least CPLGetPageSize(), but potentially |
| 261 | * larger. |
| 262 | * |
| 263 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 264 | * @return the page size |
| 265 | * |
| 266 | * @since GDAL 2.0 |
| 267 | */ |
| 268 | size_t CPL_DLL CPLVirtualMemGetPageSize(CPLVirtualMem* ctxt); |
| 269 | |
| 270 | /** Return TRUE if this memory mapping can be accessed safely from concurrent |
| 271 | * threads. |
| 272 | * |
| 273 | * The situation that can cause problems is when several threads try to access |
| 274 | * a page of the mapping that is not yet mapped. |
| 275 | * |
| 276 | * The return value of this function depends on whether bSingleThreadUsage has |
| 277 | * been set of not in CPLVirtualMemNew() and/or the implementation. |
| 278 | * |
| 279 | * On Linux, this will always return TRUE if bSingleThreadUsage = FALSE. |
| 280 | * |
| 281 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 282 | * @return TRUE if this memory mapping can be accessed safely from concurrent |
| 283 | * threads. |
| 284 | * |
| 285 | * @since GDAL 2.0 |
| 286 | */ |
| 287 | int CPL_DLL CPLVirtualMemIsAccessThreadSafe(CPLVirtualMem* ctxt); |
| 288 | |
| 289 | /** Declare that a thread will access a virtual memory mapping. |
| 290 | * |
| 291 | * This function must be called by a thread that wants to access the |
| 292 | * content of a virtual memory mapping, except if the virtual memory mapping has |
| 293 | * been created with bSingleThreadUsage = TRUE. |
| 294 | * |
| 295 | * This function must be paired with CPLVirtualMemUnDeclareThread(). |
| 296 | * |
| 297 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 298 | * |
| 299 | * @since GDAL 2.0 |
| 300 | */ |
| 301 | void CPL_DLL CPLVirtualMemDeclareThread(CPLVirtualMem* ctxt); |
| 302 | |
| 303 | /** Declare that a thread will stop accessing a virtual memory mapping. |
| 304 | * |
| 305 | * This function must be called by a thread that will no longer access the |
| 306 | * content of a virtual memory mapping, except if the virtual memory mapping has |
| 307 | * been created with bSingleThreadUsage = TRUE. |
| 308 | * |
| 309 | * This function must be paired with CPLVirtualMemDeclareThread(). |
| 310 | * |
| 311 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 312 | * |
| 313 | * @since GDAL 2.0 |
| 314 | */ |
| 315 | void CPL_DLL CPLVirtualMemUnDeclareThread(CPLVirtualMem* ctxt); |
| 316 | |
| 317 | /** Make sure that a region of virtual memory will be realized. |
| 318 | * |
| 319 | * Calling this function is not required, but might be usefull when debugging |
| 320 | * a process with tools like gdb or valgrind that do not naturally like |
| 321 | * segmentation fault signals. |
| 322 | * |
| 323 | * It is also needed when wanting to provide part of virtual memory mapping |
| 324 | * to a system call such as read() or write(). If read() or write() is called |
| 325 | * on a memory region not yet realized, the call will fail with EFAULT. |
| 326 | * |
| 327 | * @param ctxt context returned by CPLVirtualMemNew(). |
| 328 | * @param pAddr the memory region to pin. |
| 329 | * @param nSize the size of the memory region. |
| 330 | * @param bWriteOp set to TRUE if the memory are will be accessed in write mode. |
| 331 | * |
| 332 | * @since GDAL 2.0 |
| 333 | */ |
| 334 | void CPL_DLL CPLVirtualMemPin(CPLVirtualMem* ctxt, |
| 335 | void* pAddr, size_t nSize, int bWriteOp); |
| 336 | |
| 337 | /** Cleanup any resource and handlers related to virtual memory. |
| 338 | * |
| 339 | * This function must be called after the last CPLVirtualMem object has |
| 340 | * been freed. |
| 341 | * |
| 342 | * @since GDAL 2.0 |
| 343 | */ |
| 344 | void CPL_DLL CPLVirtualMemManagerTerminate(void); |
| 345 | |
| 346 | }}} |
| 347 | |
| 348 | === Implemented by gdalvirtualmem.cpp === |
| 349 | |
| 350 | {{{ |
| 351 | |
| 352 | |
| 353 | /** Create a CPLVirtualMem object from a GDAL dataset object. |
| 354 | * |
| 355 | * Only supported on Linux for now. |
| 356 | * |
| 357 | * This method allows creating a virtual memory object for a region of one |
| 358 | * or more GDALRasterBands from this dataset. The content of the virtual |
| 359 | * memory object is automatically filled from dataset content when a virtual |
| 360 | * memory page is first accessed, and it is released (or flushed in case of a |
| 361 | * "dirty" page) when the cache size limit has been reached. |
| 362 | * |
| 363 | * The pointer to access the virtual memory object is obtained with |
| 364 | * CPLVirtualMemGetAddr(). It remains valid until CPLVirtualMemFree() is called. |
| 365 | * |
| 366 | * If p is such a pointer and base_type the C type matching eBufType, for default |
| 367 | * values of spacing parameters, the element of image coordinates (x, y) |
| 368 | * (relative to xOff, yOff) for band b can be accessed with |
| 369 | * ((base_type*)p)[x + y * nBufXSize + (b-1)*nBufXSize*nBufYSize]. |
| 370 | * |
| 371 | * Note that the mechanism used to transparently fill memory pages when they are |
| 372 | * accessed is the same (but in a controlled way) than what occurs when a memory |
| 373 | * error occurs in a program. Debugging software will generally interrupt program |
| 374 | * execution when that happens. If needed, CPLVirtualMemPin() can be used to avoid |
| 375 | * that by ensuring memory pages are allocated before being accessed. |
| 376 | * |
| 377 | * The size of the region that can be mapped as a virtual memory object depends |
| 378 | * on hardware and operating system limitations. |
| 379 | * On Linux AMD64 platforms, the maximum value is 128 TB. |
| 380 | * On Linux x86 platforms, the maximum value is 2 GB. |
| 381 | * |
| 382 | * Data type translation is automatically done if the data type |
| 383 | * (eBufType) of the buffer is different than |
| 384 | * that of the GDALRasterBand. |
| 385 | * |
| 386 | * Image decimation / replication is currently not supported, i.e. if the |
| 387 | * size of the region being accessed (nXSize x nYSize) is different from the |
| 388 | * buffer size (nBufXSize x nBufYSize). |
| 389 | * |
| 390 | * The nPixelSpace, nLineSpace and nBandSpace parameters allow reading into or |
| 391 | * writing from various organization of buffers. Arbitrary values for the spacing |
| 392 | * parameters are not supported. Those values must be multiple of the size of the |
| 393 | * buffer data type, and must be either band sequential organization (typically |
| 394 | * nPixelSpace = GDALGetDataTypeSize(eBufType) / 8, nLineSpace = nPixelSpace * nBufXSize, |
| 395 | * nBandSpace = nLineSpace * nBufYSize), or pixel-interleaved organization |
| 396 | * (typically nPixelSpace = nBandSpace * nBandCount, nLineSpace = nPixelSpace * nBufXSize, |
| 397 | * nBandSpace = GDALGetDataTypeSize(eBufType) / 8) |
| 398 | * |
| 399 | * @param hDS Dataset object |
| 400 | * |
| 401 | * @param eRWFlag Either GF_Read to read a region of data, or GF_Write to |
| 402 | * write a region of data. |
| 403 | * |
| 404 | * @param nXOff The pixel offset to the top left corner of the region |
| 405 | * of the band to be accessed. This would be zero to start from the left side. |
| 406 | * |
| 407 | * @param nYOff The line offset to the top left corner of the region |
| 408 | * of the band to be accessed. This would be zero to start from the top. |
| 409 | * |
| 410 | * @param nXSize The width of the region of the band to be accessed in pixels. |
| 411 | * |
| 412 | * @param nYSize The height of the region of the band to be accessed in lines. |
| 413 | * |
| 414 | * @param nBufXSize the width of the buffer image into which the desired region |
| 415 | * is to be read, or from which it is to be written. |
| 416 | * |
| 417 | * @param nBufYSize the height of the buffer image into which the desired |
| 418 | * region is to be read, or from which it is to be written. |
| 419 | * |
| 420 | * @param eBufType the type of the pixel values in the data buffer. The |
| 421 | * pixel values will automatically be translated to/from the GDALRasterBand |
| 422 | * data type as needed. |
| 423 | * |
| 424 | * @param nBandCount the number of bands being read or written. |
| 425 | * |
| 426 | * @param panBandMap the list of nBandCount band numbers being read/written. |
| 427 | * Note band numbers are 1 based. This may be NULL to select the first |
| 428 | * nBandCount bands. |
| 429 | * |
| 430 | * @param nPixelSpace The byte offset from the start of one pixel value in |
| 431 | * the buffer to the start of the next pixel value within a scanline. If defaulted |
| 432 | * (0) the size of the datatype eBufType is used. |
| 433 | * |
| 434 | * @param nLineSpace The byte offset from the start of one scanline in |
| 435 | * the buffer to the start of the next. If defaulted (0) the size of the datatype |
| 436 | * eBufType * nBufXSize is used. |
| 437 | * |
| 438 | * @param nBandSpace the byte offset from the start of one bands data to the |
| 439 | * start of the next. If defaulted (0) the value will be |
| 440 | * nLineSpace * nBufYSize implying band sequential organization |
| 441 | * of the data buffer. |
| 442 | * |
| 443 | * @param nCacheSize size in bytes of the maximum memory that will be really |
| 444 | * allocated (must ideally fit into RAM) |
| 445 | * |
| 446 | * @param nPageSizeHint hint for the page size. Must be a multiple of the |
| 447 | * system page size, returned by CPLGetPageSize(). |
| 448 | * Minimum value is generally 4096. Might be set to 0 to |
| 449 | * let the function determine a default page size. |
| 450 | * |
| 451 | * @param bSingleThreadUsage set to TRUE if there will be no concurrent threads |
| 452 | * that will access the virtual memory mapping. This can |
| 453 | * optimize performance a bit. If set to FALSE, |
| 454 | * CPLVirtualMemDeclareThread() must be called. |
| 455 | * |
| 456 | * @param papszOptions NULL terminated list of options. Unused for now. |
| 457 | * |
| 458 | * @return a virtual memory object that must be freed by CPLVirtualMemFree(), |
| 459 | * or NULL in case of failure. |
| 460 | * |
| 461 | * @since GDAL 2.0 |
| 462 | */ |
| 463 | |
| 464 | CPLVirtualMem CPL_DLL* GDALDatasetGetVirtualMem( GDALDatasetH hDS, |
| 465 | GDALRWFlag eRWFlag, |
| 466 | int nXOff, int nYOff, |
| 467 | int nXSize, int nYSize, |
| 468 | int nBufXSize, int nBufYSize, |
| 469 | GDALDataType eBufType, |
| 470 | int nBandCount, int* panBandMap, |
| 471 | int nPixelSpace, |
| 472 | GIntBig nLineSpace, |
| 473 | GIntBig nBandSpace, |
| 474 | size_t nCacheSize, |
| 475 | size_t nPageSizeHint, |
| 476 | int bSingleThreadUsage, |
| 477 | char **papszOptions ); |
| 478 | |
| 479 | |
| 480 | |
| 481 | /** Create a CPLVirtualMem object from a GDAL dataset object. |
| 482 | * |
| 483 | * Only supported on Linux for now. |
| 484 | * |
| 485 | * This method allows creating a virtual memory object for a region of a |
| 486 | * GDALRasterBand. The content of the virtual |
| 487 | * memory object is automatically filled from dataset content when a virtual |
| 488 | * memory page is first accessed, and it is released (or flushed in case of a |
| 489 | * "dirty" page) when the cache size limit has been reached. |
| 490 | * |
| 491 | * The pointer to access the virtual memory object is obtained with |
| 492 | * CPLVirtualMemGetAddr(). It remains valid until CPLVirtualMemFree() is called. |
| 493 | * |
| 494 | * If p is such a pointer and base_type the C type matching eBufType, for default |
| 495 | * values of spacing parameters, the element of image coordinates (x, y) |
| 496 | * (relative to xOff, yOff) can be accessed with |
| 497 | * ((base_type*)p)[x + y * nBufXSize]. |
| 498 | * |
| 499 | * Note that the mechanism used to transparently fill memory pages when they are |
| 500 | * accessed is the same (but in a controlled way) than what occurs when a memory |
| 501 | * error occurs in a program. Debugging software will generally interrupt program |
| 502 | * execution when that happens. If needed, CPLVirtualMemPin() can be used to avoid |
| 503 | * that by ensuring memory pages are allocated before being accessed. |
| 504 | * |
| 505 | * The size of the region that can be mapped as a virtual memory object depends |
| 506 | * on hardware and operating system limitations. |
| 507 | * On Linux AMD64 platforms, the maximum value is 128 TB. |
| 508 | * On Linux x86 platforms, the maximum value is 2 GB. |
| 509 | * |
| 510 | * Data type translation is automatically done if the data type |
| 511 | * (eBufType) of the buffer is different than |
| 512 | * that of the GDALRasterBand. |
| 513 | * |
| 514 | * Image decimation / replication is currently not supported, i.e. if the |
| 515 | * size of the region being accessed (nXSize x nYSize) is different from the |
| 516 | * buffer size (nBufXSize x nBufYSize). |
| 517 | * |
| 518 | * The nPixelSpace and nLineSpace parameters allow reading into or |
| 519 | * writing from various organization of buffers. Arbitrary values for the spacing |
| 520 | * parameters are not supported. Those values must be multiple of the size of the |
| 521 | * buffer data type and must be such that nLineSpace >= nPixelSpace * nBufXSize. |
| 522 | * |
| 523 | * @param hBand Rasterband object |
| 524 | * |
| 525 | * @param eRWFlag Either GF_Read to read a region of data, or GF_Write to |
| 526 | * write a region of data. |
| 527 | * |
| 528 | * @param nXOff The pixel offset to the top left corner of the region |
| 529 | * of the band to be accessed. This would be zero to start from the left side. |
| 530 | * |
| 531 | * @param nYOff The line offset to the top left corner of the region |
| 532 | * of the band to be accessed. This would be zero to start from the top. |
| 533 | * |
| 534 | * @param nXSize The width of the region of the band to be accessed in pixels. |
| 535 | * |
| 536 | * @param nYSize The height of the region of the band to be accessed in lines. |
| 537 | * |
| 538 | * @param nBufXSize the width of the buffer image into which the desired region |
| 539 | * is to be read, or from which it is to be written. |
| 540 | * |
| 541 | * @param nBufYSize the height of the buffer image into which the desired |
| 542 | * region is to be read, or from which it is to be written. |
| 543 | * |
| 544 | * @param eBufType the type of the pixel values in the data buffer. The |
| 545 | * pixel values will automatically be translated to/from the GDALRasterBand |
| 546 | * data type as needed. |
| 547 | * |
| 548 | * @param nPixelSpace The byte offset from the start of one pixel value in |
| 549 | * the buffer to the start of the next pixel value within a scanline. If defaulted |
| 550 | * (0) the size of the datatype eBufType is used. |
| 551 | * |
| 552 | * @param nLineSpace The byte offset from the start of one scanline in |
| 553 | * the buffer to the start of the next. If defaulted (0) the size of the datatype |
| 554 | * eBufType * nBufXSize is used. |
| 555 | * |
| 556 | * @param nCacheSize size in bytes of the maximum memory that will be really |
| 557 | * allocated (must ideally fit into RAM) |
| 558 | * |
| 559 | * @param nPageSizeHint hint for the page size. Must be a multiple of the |
| 560 | * system page size, returned by CPLGetPageSize(). |
| 561 | * Minimum value is generally 4096. Might be set to 0 to |
| 562 | * let the function determine a default page size. |
| 563 | * |
| 564 | * @param bSingleThreadUsage set to TRUE if there will be no concurrent threads |
| 565 | * that will access the virtual memory mapping. This can |
| 566 | * optimize performance a bit. If set to FALSE, |
| 567 | * CPLVirtualMemDeclareThread() must be called. |
| 568 | * |
| 569 | * @param papszOptions NULL terminated list of options. Unused for now. |
| 570 | * |
| 571 | * @return a virtual memory object that must be freed by CPLVirtualMemFree(), |
| 572 | * or NULL in case of failure. |
| 573 | * |
| 574 | * @since GDAL 2.0 |
| 575 | */ |
| 576 | |
| 577 | typedef enum |
| 578 | { |
| 579 | /*! Tile Interleaved by Pixel: tile (0,0) with internal band interleaved |
| 580 | by pixel organization, tile (1, 0), ... */ |
| 581 | GTO_TIP, |
| 582 | /*! Band Interleaved by Tile : tile (0,0) of first band, tile (0,0) of second |
| 583 | band, ... tile (1,0) of fisrt band, tile (1,0) of second band, ... */ |
| 584 | GTO_BIT, |
| 585 | /*! Band SeQuential : all the tiles of first band, all the tiles of following band... */ |
| 586 | GTO_BSQ |
| 587 | } GDALTileOrganization; |
| 588 | |
| 589 | CPLVirtualMem CPL_DLL* GDALRasterBandGetVirtualMem( GDALRasterBandH hBand, |
| 590 | GDALRWFlag eRWFlag, |
| 591 | int nXOff, int nYOff, |
| 592 | int nXSize, int nYSize, |
| 593 | int nBufXSize, int nBufYSize, |
| 594 | GDALDataType eBufType, |
| 595 | int nPixelSpace, |
| 596 | GIntBig nLineSpace, |
| 597 | size_t nCacheSize, |
| 598 | size_t nPageSizeHint, |
| 599 | int bSingleThreadUsage, |
| 600 | char **papszOptions ); |
| 601 | |
| 602 | |
| 603 | /** Create a CPLVirtualMem object from a GDAL dataset object, with tiling |
| 604 | * organization |
| 605 | * |
| 606 | * Only supported on Linux for now. |
| 607 | * |
| 608 | * This method allows creating a virtual memory object for a region of one |
| 609 | * or more GDALRasterBands from this dataset. The content of the virtual |
| 610 | * memory object is automatically filled from dataset content when a virtual |
| 611 | * memory page is first accessed, and it is released (or flushed in case of a |
| 612 | * "dirty" page) when the cache size limit has been reached. |
| 613 | * |
| 614 | * Contrary to GDALDatasetGetVirtualMem(), pixels will be organized by tiles |
| 615 | * instead of scanlines. Different ways of organizing pixel within/accross tiles |
| 616 | * can be selected with the eTileOrganization parameter. |
| 617 | * |
| 618 | * If nXSize is not a multiple of nTileXSize or nYSize is not a multiple of |
| 619 | * nTileYSize, partial tiles will exists at the right and/or bottom of the region |
| 620 | * of interest. Those partial tiles will also have nTileXSize * nTileYSize dimension, |
| 621 | * with padding pixels. |
| 622 | * |
| 623 | * The pointer to access the virtual memory object is obtained with |
| 624 | * CPLVirtualMemGetAddr(). It remains valid until CPLVirtualMemFree() is called. |
| 625 | * |
| 626 | * If p is such a pointer and base_type the C type matching eBufType, for default |
| 627 | * values of spacing parameters, the element of image coordinates (x, y) |
| 628 | * (relative to xOff, yOff) for band b can be accessed with : |
| 629 | * - for eTileOrganization = GTO_TIP, ((base_type*)p)[tile_number(x,y)*nBandCount*tile_size + offset_in_tile(x,y)*nBandCount + (b-1)]. |
| 630 | * - for eTileOrganization = GTO_BIT, ((base_type*)p)[(tile_number(x,y)*nBandCount + (b-1)) * tile_size + offset_in_tile(x,y)]. |
| 631 | * - for eTileOrganization = GTO_BSQ, ((base_type*)p)[(tile_number(x,y) + (b-1)*nTilesCount) * tile_size + offset_in_tile(x,y)]. |
| 632 | * |
| 633 | * where nTilesPerRow = ceil(nXSize / nTileXSize) |
| 634 | * nTilesPerCol = ceil(nYSize / nTileYSize) |
| 635 | * nTilesCount = nTilesPerRow * nTilesPerCol |
| 636 | * tile_number(x,y) = (y / nTileYSize) * nTilesPerRow + (x / nTileXSize) |
| 637 | * offset_in_tile(x,y) = (y % nTileYSize) * nTileXSize + (x % nTileXSize) |
| 638 | * tile_size = nTileXSize * nTileYSize |
| 639 | * |
| 640 | * Note that for a single band request, all tile organizations are equivalent. |
| 641 | * |
| 642 | * Note that the mechanism used to transparently fill memory pages when they are |
| 643 | * accessed is the same (but in a controlled way) than what occurs when a memory |
| 644 | * error occurs in a program. Debugging software will generally interrupt program |
| 645 | * execution when that happens. If needed, CPLVirtualMemPin() can be used to avoid |
| 646 | * that by ensuring memory pages are allocated before being accessed. |
| 647 | * |
| 648 | * The size of the region that can be mapped as a virtual memory object depends |
| 649 | * on hardware and operating system limitations. |
| 650 | * On Linux AMD64 platforms, the maximum value is 128 TB. |
| 651 | * On Linux x86 platforms, the maximum value is 2 GB. |
| 652 | * |
| 653 | * Data type translation is automatically done if the data type |
| 654 | * (eBufType) of the buffer is different than |
| 655 | * that of the GDALRasterBand. |
| 656 | * |
| 657 | * @param hDS Dataset object |
| 658 | * |
| 659 | * @param eRWFlag Either GF_Read to read a region of data, or GF_Write to |
| 660 | * write a region of data. |
| 661 | * |
| 662 | * @param nXOff The pixel offset to the top left corner of the region |
| 663 | * of the band to be accessed. This would be zero to start from the left side. |
| 664 | * |
| 665 | * @param nYOff The line offset to the top left corner of the region |
| 666 | * of the band to be accessed. This would be zero to start from the top. |
| 667 | * |
| 668 | * @param nXSize The width of the region of the band to be accessed in pixels. |
| 669 | * |
| 670 | * @param nYSize The height of the region of the band to be accessed in lines. |
| 671 | * |
| 672 | * @param nTileXSize the width of the tiles. |
| 673 | * |
| 674 | * @param nTileYSize the height of the tiles. |
| 675 | * |
| 676 | * @param eBufType the type of the pixel values in the data buffer. The |
| 677 | * pixel values will automatically be translated to/from the GDALRasterBand |
| 678 | * data type as needed. |
| 679 | * |
| 680 | * @param nBandCount the number of bands being read or written. |
| 681 | * |
| 682 | * @param panBandMap the list of nBandCount band numbers being read/written. |
| 683 | * Note band numbers are 1 based. This may be NULL to select the first |
| 684 | * nBandCount bands. |
| 685 | * |
| 686 | * @param eTileOrganization tile organization. |
| 687 | * |
| 688 | * @param nCacheSize size in bytes of the maximum memory that will be really |
| 689 | * allocated (must ideally fit into RAM) |
| 690 | * |
| 691 | * @param bSingleThreadUsage set to TRUE if there will be no concurrent threads |
| 692 | * that will access the virtual memory mapping. This can |
| 693 | * optimize performance a bit. If set to FALSE, |
| 694 | * CPLVirtualMemDeclareThread() must be called. |
| 695 | * |
| 696 | * @param papszOptions NULL terminated list of options. Unused for now. |
| 697 | * |
| 698 | * @return a virtual memory object that must be freed by CPLVirtualMemFree(), |
| 699 | * or NULL in case of failure. |
| 700 | * |
| 701 | * @since GDAL 2.0 |
| 702 | */ |
| 703 | |
| 704 | CPLVirtualMem CPL_DLL* GDALDatasetGetTiledVirtualMem( GDALDatasetH hDS, |
| 705 | GDALRWFlag eRWFlag, |
| 706 | int nXOff, int nYOff, |
| 707 | int nXSize, int nYSize, |
| 708 | int nTileXSize, int nTileYSize, |
| 709 | GDALDataType eBufType, |
| 710 | int nBandCount, int* panBandMap, |
| 711 | GDALTileOrganization eTileOrganization, |
| 712 | size_t nCacheSize, |
| 713 | int bSingleThreadUsage, |
| 714 | char **papszOptions ); |
| 715 | |
| 716 | |
| 717 | /** Create a CPLVirtualMem object from a GDAL rasterband object, with tiling |
| 718 | * organization |
| 719 | * |
| 720 | * Only supported on Linux for now. |
| 721 | * |
| 722 | * This method allows creating a virtual memory object for a region of one |
| 723 | * GDALRasterBand. The content of the virtual |
| 724 | * memory object is automatically filled from dataset content when a virtual |
| 725 | * memory page is first accessed, and it is released (or flushed in case of a |
| 726 | * "dirty" page) when the cache size limit has been reached. |
| 727 | * |
| 728 | * Contrary to GDALDatasetGetVirtualMem(), pixels will be organized by tiles |
| 729 | * instead of scanlines. |
| 730 | * |
| 731 | * If nXSize is not a multiple of nTileXSize or nYSize is not a multiple of |
| 732 | * nTileYSize, partial tiles will exists at the right and/or bottom of the region |
| 733 | * of interest. Those partial tiles will also have nTileXSize * nTileYSize dimension, |
| 734 | * with padding pixels. |
| 735 | * |
| 736 | * The pointer to access the virtual memory object is obtained with |
| 737 | * CPLVirtualMemGetAddr(). It remains valid until CPLVirtualMemFree() is called. |
| 738 | * |
| 739 | * If p is such a pointer and base_type the C type matching eBufType, for default |
| 740 | * values of spacing parameters, the element of image coordinates (x, y) |
| 741 | * (relative to xOff, yOff) can be accessed with : |
| 742 | * ((base_type*)p)[tile_number(x,y)*tile_size + offset_in_tile(x,y)]. |
| 743 | * |
| 744 | * where nTilesPerRow = ceil(nXSize / nTileXSize) |
| 745 | * nTilesCount = nTilesPerRow * nTilesPerCol |
| 746 | * tile_number(x,y) = (y / nTileYSize) * nTilesPerRow + (x / nTileXSize) |
| 747 | * offset_in_tile(x,y) = (y % nTileYSize) * nTileXSize + (x % nTileXSize) |
| 748 | * tile_size = nTileXSize * nTileYSize |
| 749 | * |
| 750 | * Note that the mechanism used to transparently fill memory pages when they are |
| 751 | * accessed is the same (but in a controlled way) than what occurs when a memory |
| 752 | * error occurs in a program. Debugging software will generally interrupt program |
| 753 | * execution when that happens. If needed, CPLVirtualMemPin() can be used to avoid |
| 754 | * that by ensuring memory pages are allocated before being accessed. |
| 755 | * |
| 756 | * The size of the region that can be mapped as a virtual memory object depends |
| 757 | * on hardware and operating system limitations. |
| 758 | * On Linux AMD64 platforms, the maximum value is 128 TB. |
| 759 | * On Linux x86 platforms, the maximum value is 2 GB. |
| 760 | * |
| 761 | * Data type translation is automatically done if the data type |
| 762 | * (eBufType) of the buffer is different than |
| 763 | * that of the GDALRasterBand. |
| 764 | * |
| 765 | * @param hBand Rasterband object |
| 766 | * |
| 767 | * @param eRWFlag Either GF_Read to read a region of data, or GF_Write to |
| 768 | * write a region of data. |
| 769 | * |
| 770 | * @param nXOff The pixel offset to the top left corner of the region |
| 771 | * of the band to be accessed. This would be zero to start from the left side. |
| 772 | * |
| 773 | * @param nYOff The line offset to the top left corner of the region |
| 774 | * of the band to be accessed. This would be zero to start from the top. |
| 775 | * |
| 776 | * @param nXSize The width of the region of the band to be accessed in pixels. |
| 777 | * |
| 778 | * @param nYSize The height of the region of the band to be accessed in lines. |
| 779 | * |
| 780 | * @param nTileXSize the width of the tiles. |
| 781 | * |
| 782 | * @param nTileYSize the height of the tiles. |
| 783 | * |
| 784 | * @param eBufType the type of the pixel values in the data buffer. The |
| 785 | * pixel values will automatically be translated to/from the GDALRasterBand |
| 786 | * data type as needed. |
| 787 | * |
| 788 | * @param nCacheSize size in bytes of the maximum memory that will be really |
| 789 | * allocated (must ideally fit into RAM) |
| 790 | * |
| 791 | * @param bSingleThreadUsage set to TRUE if there will be no concurrent threads |
| 792 | * that will access the virtual memory mapping. This can |
| 793 | * optimize performance a bit. If set to FALSE, |
| 794 | * CPLVirtualMemDeclareThread() must be called. |
| 795 | * |
| 796 | * @param papszOptions NULL terminated list of options. Unused for now. |
| 797 | * |
| 798 | * @return a virtual memory object that must be freed by CPLVirtualMemFree(), |
| 799 | * or NULL in case of failure. |
| 800 | * |
| 801 | * @since GDAL 2.0 |
| 802 | */ |
| 803 | |
| 804 | CPLVirtualMem CPL_DLL* GDALRasterBandGetTiledVirtualMem( GDALRasterBandH hBand, |
| 805 | GDALRWFlag eRWFlag, |
| 806 | int nXOff, int nYOff, |
| 807 | int nXSize, int nYSize, |
| 808 | int nTileXSize, int nTileYSize, |
| 809 | GDALDataType eBufType, |
| 810 | size_t nCacheSize, |
| 811 | int bSingleThreadUsage, |
| 812 | char **papszOptions ); |
| 813 | }}} |
| 814 | |
| 815 | == Portability == |
| 816 | |
| 817 | The CPLVirtualMem low-level machinery is only implemented for Linux now. It |
| 818 | assumes that returning from a SIGSEGV handler is possible, which is a blatant |
| 819 | violation of POSIX, but in practice it seems that most POSIX (and non |
| 820 | POSIX such as Windows) systems should be able to resume execution after a |
| 821 | segmentation fault. |
| 822 | |
| 823 | Porting to other POSIX operating systems such as MacOSX should be doable with moderate |
| 824 | effort. Windows has API that offer similar capabilities as |
| 825 | POSIX API with VirtualAlloc(), VirtualProtect() and SetUnhandledExceptionFilter(), |
| 826 | although the porting would undoubtly require more effort. |
| 827 | |
| 828 | The existence of [http://www.gnu.org/software/libsigsegv libsigsegv] that run on |
| 829 | various OS is an evidence on its capacity of being ported to other platforms. |
| 830 | |
| 831 | The trickiest part is ensuring that things will work reliably when two concurrent |
| 832 | threads that try to access the same initally unmapped page. Without special care, one |
| 833 | thread could manage to access the page that is being filled by the other thread, |
| 834 | before it is completely filled. On Linux this can be easily avoided with the |
| 835 | mremap() call. When a page is filled, we don't actually pass the target page to |
| 836 | the user callback, but a temporary page. When the callback has finished its job, |
| 837 | this temporary page is mremap()'ed to its target location, which is an atomic |
| 838 | operation. An alternative implementation for POSIX systems that don't have this |
| 839 | mremap() call has been tested : any declared threads that can access the memory |
| 840 | mapping are paused before the temporary page is memcpy'ed to its target location, |
| 841 | and are resumed afterwards. This requires threads to priorly declare their |
| 842 | "interest" for a memory mapping with CPLVirtualMemDeclareThread(). Pausing a |
| 843 | thread is interestingly non-obvious : the solution found to do so is to |
| 844 | send it a SIGUSR1 signal and make it wait in a signal handler for this SIGUSR1 |
| 845 | signal... It has not been investigated if/how this could be done on Windows. |
| 846 | CPLVirtualMemIsAccessThreadSafe() has been introduced for that purpose. |
| 847 | |
| 848 | == Performance == |
| 849 | |
| 850 | No miraculous performance gain should be expected from this new capability, |
| 851 | when compared to code that carefully uses GDALRasterIO(). Handling |
| 852 | segmentation faults has a cost ( the operating system catches a hardware |
| 853 | exception, then calls the user program segmentation fault handler, which does |
| 854 | the normal GDAL I/O operations, and plays with page mappings and permissions |
| 855 | which invalidate some CPU caches, etc... ). However, when a page has been realized, |
| 856 | access to it should be really fast, so with appropriate access patterns and |
| 857 | cache size, good performance should be expected. |
| 858 | |
| 859 | It should also be noted that in the current implementation, the realization of |
| 860 | pages is done in a serialized way, that is to say if 2 threads which use 2 different |
| 861 | memory mappings cause a segmentation fault at the same time, they will not be |
| 862 | dealt by 2 different threads, but one after the other one. |
| 863 | |
| 864 | == Limitations == |
| 865 | |
| 866 | The maximum size of the virtual memory space (and thus a virtual memory mapping) |
| 867 | depends on the CPU architecture and OS limitations : |
| 868 | * on Linux AMD64, 128 TB. |
| 869 | * on Linux x86, 2 GB. |
| 870 | * On Windows AMD64 (unsupported by the current implementation), 8 TB. |
| 871 | * On Windows x86 (unsupported by the current implementation), 2 GB. |
| 872 | |
| 873 | Clearly, the main interest of this new functionality is for AMD64 platforms. |
| 874 | |
| 875 | On a Linux AMD64 machine with 4 GB RAM, the Python binding of |
| 876 | GDALDatasetGetTiledVirtualMem() has been successfully used to access random points |
| 877 | on the new [http://www.eea.europa.eu/data-and-maps/data/eu-dem/ Europe 3'' DEM dataset], |
| 878 | which is a 20 GB compressed GeoTIFF ( and 288000 * 180000 * 4 = 193 GB uncompressed ) |
| 879 | |
| 880 | == Related thoughts == |
| 881 | |
| 882 | With an uncompressed GeoTIFF file (where strips or tiles are sequentially written |
| 883 | to disk), GDALDatasetGetVirtualMem() and GDALDatasetGetTiledVirtualMem(), with |
| 884 | appropriate input parameters, could potentially just mmap() the file itself, which |
| 885 | would save any GDAL overhead. It is no clear however how old accessed pages can |
| 886 | be evicted from RAM since Linux does not seem to discard them, which tend to cause |
| 887 | undesirable disk swapping when the memory mapping is bigger than RAM. |
| 888 | |
| 889 | Some issues with system calls such as read() or write(), or easier multi-threading |
| 890 | could potentially be solved by making a FUSE (File system in USEr space) driver that |
| 891 | would expose a GDAL dataset as a file, and the mmap()'ing the file itself. The |
| 892 | issue raised in the previous paragraph would still apply. Plus the fact that |
| 893 | FUSE drivers are only available on POSIX OS, and need root priviledge to be |
| 894 | mounted (a FUSE filesystem does not need root priviledge to run, but the mounting |
| 895 | operation does). |
| 896 | |
| 897 | == Open questions == |
| 898 | |
| 899 | Due to the fact that it currently only works on Linux, should we mark the API |
| 900 | as experimental for now ? |
| 901 | |
| 902 | == Backward compatibility issues == |
| 903 | |
| 904 | None: new API. |
| 905 | |
| 906 | == SWIG bindings == |
| 907 | |
| 908 | The high level API (dataset and raster band) API is available in Python bindings. |
| 909 | |
| 910 | GDALDatasetGetVirtualMem() is mapped as Dataset.GetVirtualArray(), which |
| 911 | returns a NumPy array. |
| 912 | |
| 913 | {{{ |
| 914 | def GetVirtualMemArray(self, eAccess = gdalconst.GF_Read, xoff=0, yoff=0, |
| 915 | xsize=None, ysize=None, bufxsize=None, bufysize=None, |
| 916 | datatype = None, band_list = None, band_sequential = True, |
| 917 | cache_size = 10 * 1024 * 1024, page_size_hint = 0): |
| 918 | """Return a NumPy array for the dataset, seen as a virtual memory mapping. |
| 919 | If there are several bands and band_sequential = True, an element is |
| 920 | accessed with array[band][y][x]. |
| 921 | If there are several bands and band_sequential = False, an element is |
| 922 | accessed with array[y][x][band]. |
| 923 | If there is only one band, an element is accessed with array[y][x]. |
| 924 | """ |
| 925 | }}} |
| 926 | |
| 927 | Similarly for GDALDatasetGetTiledVirtualMem() : |
| 928 | |
| 929 | {{{ |
| 930 | def GetTiledVirtualMemArray(self, eAccess = gdalconst.GF_Read, xoff=0, yoff=0, |
| 931 | xsize=None, ysize=None, tilexsize=256, tileysize=256, |
| 932 | datatype = None, band_list = None, tile_organization = gdalconst.GTO_BSQ, |
| 933 | cache_size = 10 * 1024 * 1024): |
| 934 | """Return a NumPy array for the dataset, seen as a virtual memory mapping with |
| 935 | a tile organization. |
| 936 | If there are several bands and tile_organization = gdal.GTO_BIP, an element is |
| 937 | accessed with array[tiley][tilex][y][x][band]. |
| 938 | If there are several bands and tile_organization = gdal.GTO_BTI, an element is |
| 939 | accessed with array[tiley][tilex][band][y][x]. |
| 940 | If there are several bands and tile_organization = gdal.GTO_BSQ, an element is |
| 941 | accessed with array[band][tiley][tilex][y][x]. |
| 942 | If there is only one band, an element is accessed with array[tiley][tilex][y][x]. |
| 943 | """ |
| 944 | }}} |
| 945 | |
| 946 | And the Band object has the following 2 methods : |
| 947 | |
| 948 | {{{ |
| 949 | def GetVirtualMemArray(self, eAccess = gdalconst.GF_Read, xoff=0, yoff=0, |
| 950 | xsize=None, ysize=None, bufxsize=None, bufysize=None, |
| 951 | datatype = None, |
| 952 | cache_size = 10 * 1024 * 1024, page_size_hint = 0): |
| 953 | """Return a NumPy array for the band, seen as a virtual memory mapping. |
| 954 | An element is accessed with array[y][x]. |
| 955 | """ |
| 956 | |
| 957 | def GetTiledVirtualMemArray(self, eAccess = gdalconst.GF_Read, xoff=0, yoff=0, |
| 958 | xsize=None, ysize=None, tilexsize=256, tileysize=256, |
| 959 | datatype = None, |
| 960 | cache_size = 10 * 1024 * 1024): |
| 961 | """Return a NumPy array for the band, seen as a virtual memory mapping with |
| 962 | a tile organization. |
| 963 | An element is accessed with array[tiley][tilex][y][x]. |
| 964 | """ |
| 965 | }}} |
| 966 | |
| 967 | Note: dataset/Band.GetVirtualMem()/GetTiledVirtualMem() methods are also available. |
| 968 | They return a VirtualMem python object that has a GetAddr() method that returns |
| 969 | a Python memoryview object (Python 2.7 or later required). However, using such |
| 970 | object does not seem practical for non-Byte data types. |
| 971 | |
| 972 | == Test Suite == |
| 973 | |
| 974 | The autotest suite will be extended to test the Python API of this RFC. In |
| 975 | autotest/cpp, a test_virtualmem.cpp file tests concurrent access to the same |
| 976 | pages by 2 threads. |
| 977 | |
| 978 | == Implementation == |
| 979 | |
| 980 | Implementation will be done by Even Rouault in GDAL/OGR trunk. The proposed |
| 981 | implementation is attached as a patch. |
