Changes between Version 65 and Version 66 of rfc24_progressive_data_support
- Apr 8, 2009, 4:52:24 PM (15 years ago)
v65 v66 61 61 [[Image(gdalsequence.PNG)]] 62 62 63 1. GDALGetDatasetDriver 63 1. GDALGetDatasetDriver:: 64 64 Fetch the driver to which this dataset relates. 65 1. Open 65 1. Open:: 66 66 If the filename contained in the GDALOpenInfo object has a case insensitive URI scheme of jpip or jpips the JPIPKAKDataset is created and initialised, otherwise NULL is returned. 67 1. Initialize 67 1. Initialize:: 68 68 Initialisation involves making an initial connection to the JPIP Server to establish a session and to retrieve the initial metadata about the image (ref. JPIP Sequence Diagram). 69 69 If the connection fails, the function returns false and the Open function returns NULL indicating that opening the dataset with this driver failed.
