Changes between Version 6 and Version 7 of rfc20_srs_axes
- Jan 10, 2008, 1:47:26 PM (17 years ago)
rfc20_srs_axes
v6 v7 47 47 == OGRSpatialReference == 48 48 49 New methods: 49 === New methods === 50 50 51 51 {{{ … … 68 68 Note that OGRSpatialReference::!StripNodes( "AXIS" ); can be used to strip axis definitions where they are not desired. 69 69 70 Changed Methods: 70 === importFromURN === 71 71 72 * Modify importFromURN() to set AXIS values properly for EPSG and OGC geographic coordinate systems. So urn:...:EPSG: will be assumed to really honour EPSG conventions. 72 Modify importFromURN() to set AXIS values properly for EPSG and OGC geographic coordinate systems. So urn:...:EPSG: will be assumed to really honour EPSG conventions. 73 74 === SetWellKnownGeogCS() === 75 76 This method appears to be the only code 73 77 * Modify SetWellKnownGeogCS() to *not* set AXIS values, and strip AXIS values out of any other hardcoded WKT definitions. 78 79 === importFromEPSG() === 80 74 81 * importFromEPSG() will continue to *not* set AXIS values for GEOGCS coordinate systems. 75 * importFromEPSG() *will*now set axis values for projected coordinate systems (at least in cases like Krovak where it is a non-default axis orientation).82 * importFromEPSG() will now set axis values for projected coordinate systems (at least in cases like Krovak where it is a non-default axis orientation). 76 83 77 84 == OGRCoordinateTransformation == … … 82 89 83 90 * GMLJP2 (classes in gcore/gdalgmlcoverage.cpp and gcore/gdaljp2metadata.cpp). 84 * WCS 85 * WMS (maybe? )91 * WCS (based on interpretation of urns). 92 * WMS (maybe? actually, I suspect we don't actually get the coordinate system from the capabalities) 86 93 * OGR GML (maybe? only GML3 affected?) 94 * BSB, SAR_CEOS, ENVISAT, HDF4, JDEM, L1B, LAN, SRTMHGT: Like SetWellKnownGeogCS() these all include lat/long AXIS specifications in their hardcoded WGS84 coordinate systems. These need to be removed so they will default to being interpreted as long/lat. 87 95 88 96 == Questions ==
