Changes between Version 1 and Version 2 of rfc12_filemanagement
- Apr 29, 2007, 9:52:04 PM (17 years ago)
v1 v2 9 9 Some applications using GDAL have a requirement to provide file management operations through the GUI. This includes deleting, renaming, moving and packaging up datasets which often requires operations on several associated files. This RFC introduces an operation on a GDALDataset to identify all the dataset files, and operations move, and rename them. 10 10 11 == GetFileList() ==11 == !GetFileList() == 12 12 13 13 The following new virtual method is added on the GDALDataset class, with an analygous C function. … … 47 47 == pfnDelete() == 48 48 49 The delete operations default implementation will be extended to use the GetFileList() results.49 The delete operations default implementation will be extended to use the !GetFileList() results. 50 50 51 51 == Supporting Functions ==
