Changes between Version 54 and Version 55 of frmts_wtkraster.html
- Sep 9, 2012, 8:49:25 AM (12 years ago)
v54 v55 1 1 = '''GDAL PostGIS Raster driver documentation''' = 2 2 3 Last update: ''' April2012'''3 Last update: '''September 2012''' 4 4 5 5 '''Note for developers:''' There is a open discussion on GDAL driver design at [http://trac.osgeo.org/postgis/wiki/WKTRaster/GDALDriverSpecificationWorking PostGIS Raster wiki] … … 18 18 * Create and modify raster on PostGIS database. 19 19 20 '''Please, use GDAL 1.9.0 or higher. The driver packed with previous GDAL versions was buggy and unstable, and it won't work with the last versions of PostGIS Raster (since it was included in PostGIS trunk).'''20 '''Please, use GDAL 2.0 from trunk. The driver packed with previous GDAL versions was buggy and unstable, and it won't work with the last versions of PostGIS Raster (since it was included in PostGIS trunk).''' 21 21 22 22 Take into account that: … … 25 25 26 26 So, if you want to use GDAL PostGIS Raster driver: 27 * ALWAYS use GDAL version 1.9.0or higher.27 * ALWAYS use GDAL version 2.0 from trunk or higher. 28 28 * Apart from this, if you want to use the driver against your own PostGIS version, use PostGIS 2.0 29 29 == '''1.1 - Credits''' ==
