Changes between Version 1 and Version 2 of Release/3.0.2-News
- Nov 4, 2019, 5:54:24 AM (5 years ago)
Release/3.0.2-News
v1 v2 16 16 == GDAL core == 17 17 18 * fix non-neareset resampling over nodata blocks ( #1941)18 * fix non-neareset resampling over nodata blocks ([https://github.com/OSGeo/gdal/issues/1941 #1941]) 19 19 20 20 == GDAL utilities == 21 21 22 * gdalwarp: adjust nodata values, passed with -srcnodata/-dstnodata, and close to FLT_MAX to exactly it ( #1724)23 * Python scripts: GetOutputDriverFor(): fixes error when multiple drivers found ( #1719)22 * gdalwarp: adjust nodata values, passed with -srcnodata/-dstnodata, and close to FLT_MAX to exactly it ([https://github.com/OSGeo/gdal/issues/1724 #1724]) 23 * Python scripts: GetOutputDriverFor(): fixes error when multiple drivers found ([https://github.com/OSGeo/gdal/issues/1719 #1719]) 24 24 25 25 == GDAL drivers == 26 26 27 27 BAG driver: 28 * calculate the northeast pixel corner rather than scaling the resolution, due to an incorrectly shifted northeast corner in some CARIS surveys ( #1728)28 * calculate the northeast pixel corner rather than scaling the resolution, due to an incorrectly shifted northeast corner in some CARIS surveys ([https://github.com/OSGeo/gdal/issues/1728 #1728]) 29 29 30 30 CTable2Dataset driver: … … 35 35 36 36 ENVI driver: 37 * preserve 'byte order' on update ( #1796)37 * preserve 'byte order' on update ([https://github.com/OSGeo/gdal/issues/1796 #1796]) 38 38 39 39 FITS driver: … … 58 58 JP2OpenJPEG driver: 59 59 * fix error logic in multi-threaded code causing memory corruption 60 * fix reading overviews, when tiled API is used, and the dimensions of the full resolution image are not a multiple of 2^numresolutions ( #1860)60 * fix reading overviews, when tiled API is used, and the dimensions of the full resolution image are not a multiple of 2^numresolutions ([https://github.com/OSGeo/gdal/issues/1860 #1860]) 61 61 * fix to return the proper number of bytes read when we read more than 2 GB at once (https://github.com/uclouvain/openjpeg/issues/1151) 62 62 63 63 JPEG driver: 64 * fix further calls to RasterIO after reading full image at full resolution ( #1947)64 * fix further calls to RasterIO after reading full image at full resolution ([https://github.com/OSGeo/gdal/issues/1947 #1947]) 65 65 66 66 MRF driver: … … 77 77 78 78 PDS4 driver: 79 * support reading a_axis_radius and c_axis_radius ( #1851)79 * support reading a_axis_radius and c_axis_radius ([https://github.com/OSGeo/gdal/issues/1851 #1851]) 80 80 81 81 SAFE driver: … … 116 116 117 117 LIBKML driver: 118 * make it accept /vsigzip/foo.kml.gz files ( #1743)118 * make it accept /vsigzip/foo.kml.gz files ([https://github.com/OSGeo/gdal/issues/1743 #1743]) 119 119 * fix potential memory leak. (Coverity 1404148) 120 120 121 121 MITAB driver: 122 * Update WindowsLatin2 definition ( #1571)122 * Update WindowsLatin2 definition ([https://github.com/OSGeo/gdal/issues/1571 #1571]) 123 123 * fix potential double-free (Coverity 1404224) 124 124 * avoid potential nullptr deref (Coverity 1404174) 125 125 126 126 PDF driver: 127 * fix reading polygon with holes and Bezier curves ( #1932)127 * fix reading polygon with holes and Bezier curves ([https://github.com/OSGeo/gdal/issues/1932 #1932]) 128 128 * fix reading strings with escape sequences 129 129 130 130 PostgreSQL driver: 131 * add support for PostgreSQL 12 ( #1692)132 * be more restrictive when deducing non-nullability of columns in SQL result layers ( #1734)131 * add support for PostgreSQL 12 ([https://github.com/OSGeo/gdal/issues/1692 #1692]) 132 * be more restrictive when deducing non-nullability of columns in SQL result layers ([https://github.com/OSGeo/gdal/issues/1734 #1734]) 133 133 134 134 Selafin driver: … … 136 136 137 137 S57 driver: 138 * s57objectclasses.csv: add missing TXTDSC attribute for DRYDOC class ( #1723)138 * s57objectclasses.csv: add missing TXTDSC attribute for DRYDOC class ([https://github.com/OSGeo/gdal/issues/1723 #1723]) 139 139 140 140 XLSX driver: … … 142 142 143 143 WFS3/OAPIF driver: 144 * correctly handle user query string parameters in connection URL ( #1710)145 * align with the final state of the OGC API - Features : Core 1.0 spec ( #1878)144 * correctly handle user query string parameters in connection URL ([https://github.com/OSGeo/gdal/issues/1710 #1710]) 145 * align with the final state of the OGC API - Features : Core 1.0 spec ([https://github.com/OSGeo/gdal/issues/1878 #1878]) 146 146 147 147 == Python bindings == 148 148 149 * add compatibility with SWIG 4.0 ( #1702)149 * add compatibility with SWIG 4.0 ([https://github.com/OSGeo/gdal/issues/1702 #1702]) 150 150 * Fix swig python wheel on darwin
