| 1 | === GDAL 1.6.2 === |
| 2 | |
| 3 | 7/31/2009 |
| 4 | |
| 5 | General: |
| 6 | * OGR expression parser causes access violations with large expressions (#2996) |
| 7 | * OGR cannot open/handle .DBF files > 2 GB (#3011) |
| 8 | * crash in cpl_vsil_win32.cpp when compiling as x64 under Windows (#3035) |
| 9 | * create index sql execute problem (#3044) |
| 10 | * GTiffDataset::FlushCache() cause crashes when used just after dataset creation (#3067) |
| 11 | * GDALDefaultOverviews::BuildOverviews() causes out-of-bounds writes for a 1x1 dataset (#3069) |
| 12 | * gdaladdo crashes on a 16-bit dataset when external overviews are requested to have JPEG compression (#3070) |
| 13 | * Corrupt EXIF info can cause stack buffer overflow in JPEG driver (#3078) |
| 14 | |
| 15 | GDAL: |
| 16 | * GenBin driver problems (#2730) |
| 17 | * Additional dependency to libgdal.so added during linking in gdal/apps (#2970) |
| 18 | * This NITF Can not be opened (endless loop) with recent GDAL (#3001) |
| 19 | * This NITF Can not be opened (endless loop) with recent GDAL (#3002) |
| 20 | * PPM Driver 16bit Support Byte Order Decision Questionable (#3012) |
| 21 | * GDAL changes projection parameter values (#3017) |
| 22 | * bad reading of AAIGRID dataset whose last line doesn't have a linebreak character (#3022) |
| 23 | * HDF5 Subdataset Issue (#3024) |
| 24 | * jp2kak driver can't display this unsigned 16 bit J2K image (#3027) |
| 25 | * NITF PRJPSB TRE handling wrong for Transverse Mercator (#3029) |
| 26 | * gdaladdo not producing correct overviews for greyscale+alpha image (#3033) |
| 27 | * GDALLoadRPB/IMDFile fails with path (#3047) |
| 28 | * Setting stats and histogram to JP2 compressed NITF corrupts the aux.xml (#3051) |
| 29 | * poBand->SetMetadataItem( "source_0", szFilterSourceXML, "vrt_sources" ) not supported as expected (#3052) |
| 30 | * gdaladdo fails with JPEG YCBCR when interleaving is not specified to be pixel (#3064) |
| 31 | * georaster - NLS problem with XML metadata (#3066) |
| 32 | * gdalwarp can crash when reprojecting into an irrelevant SRS (#3079) |
| 33 | |
| 34 | OGR: |
| 35 | * Relax KML driver about xmlns (#3004) |
| 36 | * KML driver painfully slow when reading huge geometries (#3005) |
| 37 | * PG driver does not recognize 'real' data type (#3006) |
| 38 | * X-Plane reader: Bezier curves in Pavement and APTLinefeature not curved (#3030) |
| 39 | |
| 40 | OGR Spatial References: |
| 41 | * Mercator with scale=1 at non-equatoral latitude handled improperly. (#3026) |
| 42 | * Hotine Oblique Mercator translation to PROJ.4 format looses scale factor. (#3032) |
| 43 | * Equidistant Conic ESRI Morphing Broken (#3086) |
| 44 | |
| 45 | Python: |
| 46 | * OGRFeature.SetField segfault (#3000) |
| 47 | |
| 48 | .NET: |
| 49 | * C# Osr.GetProjectionMethodParameterList / OPTGetParameterList Access Violation (#3018) |
| 50 | * [PATCH - C#] Dataset.ReadRaster()/WriteRaster() doesn't work on multi-band datasets (#3073) |
| 51 | |
