| 1 | = GDAL/OGR 1.5.3 = |
| 2 | |
| 3 | * #601 (GTiff): Correct handling of non-degree angular units. |
| 4 | * #2285 (Python): Handle other pixel types in BandWriteArray() (64bit pct2rgb) |
| 5 | * #2604 (configure): Better support for cross compiling. |
| 6 | * #2601 (PGeo): Correct TestCapability() return values. |
| 7 | * #2593 (ECW): Warn/error on illegal pixel data types written. |
| 8 | * #2591 (NetCDF): Fix extreme memory use for large images. |
| 9 | * #2589 (Shape): Various fixes for inner/outer ring categorization. |
| 10 | * #2598 (ERS): Add support for HeaderOffset keyword. |
| 11 | * #2596 (NITF): Fallback to .aux.xml (PAM) for nodata values. |
| 12 | * #2586 (alg): Fix gdalsimplewarp on 64bit platforms. |
| 13 | * #2575 (SRS): Improve oblique mercator morphing to/from ESRI PE format. |
| 14 | * #2579 (FITS): Fix int32 case on 64bit platforms. |
| 15 | * #2576 (raw): Fix crash when pixel offset is zero. |
| 16 | * #2573 (ISIS3): Fix handling of multiband tiled files. |
| 17 | * #2571 (ILWIS): Avoid exporting global called 'line'. |
| 18 | * #2243 (HFA): Add FORCETOPESTRING option, ProjectionX applied to all bands. |
| 19 | * #2564 (warper): Fix CInt16 support in warper. |
| 20 | * #2562 (PAM): Allow empty category in .aux.xml and .vrt |
| 21 | * #2546 (GTiff): Fix problems updating geotiff SRS in place. |
| 22 | * #2554 (testepsg): Now built by default. |
| 23 | * #2548 (esri2wkt): Fixed for use with NG Python bindings. |
| 24 | * #???? (SDE): Remove inappropriate errors generation in SDE Open. |
| 25 | * #???? (ECW): Correct manifest generation for plugin. |
| 26 | * #2443 (JPEG): Improved handling for YCbCr, CMYK and YCbCrK JPEG files. |
| 27 | * #2523 (HFA): Fix problem with compressed files with uninitialized blocks. |
| 28 | * #2535 (JPEG): Fix restart problem in rare circumstances. |
| 29 | * #2532 (NITF): Support decoding 12bit images. |
| 30 | * #2533 (SRS): Ensure Clear() properly clears OGRSpatialReference state. |
| 31 | * #2220 (OGR SQL): Improved string quote handling in OGR SQL. |
| 32 | * #2528 (gcore): Fixed nodata mask handling for negative integer bands. |
| 33 | * #1979 (port): Correct problems with CPLSPrintf/CPLString use. |
| 34 | * #2525 (HFA): Fix crash in compressing data larger than 16bits. |
| 35 | * #2425 (HFA): Open dependent file with same permissions as master file. |
| 36 | * #2518 (warper): Fix thread handling in multiprocessing case. |
| 37 | * #2513 (E00): Error out instead of crashing on compressed E00 files. |
| 38 | * #2512 (GTiff): Ensure flushing works properly. |
| 39 | * #1345 (configure): Improve PROJ.4 related search logic. |
| 40 | * #2505 (HFA): Support nodata from .aux file. |
| 41 | * #2508 (gdal_grid): Fix geotransform when -txe, -tye not provided. |
| 42 | * #2504 (gcore): Fix nodata masking generation for odd pixel types. |
| 43 | * #2499 (gcore): Fix crash in creation option validation. |
| 44 | * #2494 (HDF4): Removed useless and dangerous redefinition of sincos(). |
| 45 | * #2459 (swig): Improve handling of strings the caller may not change. |
| 46 | * #2475 (NITF): Fix 'adding BLOCKA TRE precludes writing IGEOLO' |
| 47 | * #???? (swig): fix typemaps for SetMetadata() |
| 48 | * #2426, #1986, #1677 (swig): Added to support GetGCPs, SetGCPs and GCPsToGeoTransform in the C# bindings |
| 49 | * #2473 (swig): Avoid boolean related compile warning |
| 50 | * #2471 (HFA): Avoid using .aux files with mismatched raster model. |
| 51 | * #2472 (PCRaster): Add overview support. |
| 52 | * #2465 (ADRG): Fix warning about not supporting update access. |
| 53 | * #2464 (NetCDF): Fixed windows plugin name. |
| 54 | * #2410 (MRSID): Improve support for DSDK 7.x. |
| 55 | * #2457 (gcore): Improve reading when block cache is too small. |
| 56 | * #2360 (GTiff): Fix problems writing odd bit depths. |
| 57 | * #2455 (ogr2ogr): Fix the -gt option operation. |
| 58 | * #2454 (ogr core): improve spatial filtering with polygons with holes. |
| 59 | * #2451 (wince): Fix CPLStrtodDelim() building on WinCE. |
| 60 | * #2449 (GTiff): Fix crash when using BLOCKYSIZE=1 for tiled files. |
| 61 | * #2448 (GTiff): Handle mix of TIFF+PAM metadata properly. |
| 62 | * #2428 (Shape): Add OGR_ORGANIZE_POLYGONS configuration option. |
| 63 | * #2427 (HFA): Correct some problems with unitialized blocks and updating. |
| 64 | * #2422 (HFA): Improve save/load of names for SRS. |
| 65 | * #2437 (port): Improve handling of large file errors on different platforms. |
| 66 | * #2415 (PAM/VRT): store nodata values in binary form to preserve precision. |
| 67 | * #2436 (HFA): Support writing 1/2/4 bit data. |
| 68 | * #2320 (ECW/JP2ECW): Fix up plugin naming. |
| 69 | * #2435 (GTiff): Push JPEG compressed data into block cache to avoid redecoding |
| 70 | * #2434 (alg): Make GeoLoc transformer more robust in case of errors. |
| 71 | * #1000 (HFA): Fix reading of reduced precision 32bit floating point blocks. |
| 72 | * #2396 (FITS): Fix crash if metadata is found. |
| 73 | * #2409 (ogr2ogr): Force -gt to 1 with -skipfailures. |
| 74 | |
