Changes between Version 1 and Version 2 of NetCDF_Improvements
- Aug 28, 2011, 10:40:51 PM (13 years ago)
NetCDF_Improvements
v1 v2 23 23 * NetCDF created by GDAL not CF-1.0 compliant for geographical grids (issue #2129) - patch submitted 24 24 * netcdf driver does not read CF-1.0 coordinate system properly (issue #2893) 25 25 * support packed data (with add_offset and scale_factor) 26 26 27 27 == 2 - Metadata == … … 48 48 49 49 50 51 50 == 4 - Dimension issues == 52 51 … … 54 53 55 54 56 == 5 - Compatibility with other software == 55 == 5 - I/O issues == 56 57 * Fix access to different netcdf file types: nc (classic), nc2 (64-bit) and nc4 (NetCDF4 with HDF5 support) - #3890 and #2379 58 * Add option for file type at export 59 * Support compressed netcdf data (szip, zip) and CF-1 packed data 60 61 == 6 - Compatibility with other software == 57 62 58 63 The driver should be compatible for import and/or export (with proper visualisation) with at least the following software: … … 65 70 * others to come... 66 71 67 68 == 6 - Test files == 72 == 7 - Test files == 69 73 70 74 A place should be set up to store NetCDF sample files, provided they are free under the terms of http://download.osgeo.org/gdal/data/COPYING . [[BR]] … … 73 77 74 78 75 == 7- Contribution ==79 == 8 - Contribution == 76 80 77 81 * Contributors are welcome and could be identified here in 3 categories: Ideas/reporting, testing, and/or development.
