Changes between Version 14 and Version 15 of HDF
- May 10, 2016, 7:29:24 AM (8 years ago)
HDF
v14 v15 74 74 EXTRAFLAGS = -I$(HDF5_INCLUDE) -DWIN32 -D_HDF5USEDLL_ 75 75 }}} 76 * note that if you build against the static HDF5 lib (libhd5.lib) you will have to use the "-D_HDF5USEDLL_" as above; but if you build against the dynamic HDF5 lib (hdf5.lib) you will have to use the "-DH5_BUILT_AS_DYNAMIC_LIB" switch instead 76 77 77 78 * You can test this by executing the following in gdal\frmts\hdf:
