Changes between Version 3 and Version 4 of GeneratingVisualStudioProject
- Oct 31, 2018, 1:53:06 AM (5 years ago)
v3 v4 1 1 = Generating Visual Studio Project = 2 2 3 Use [http ://svn.osgeo.org/gdal/trunk/gdal/generate_vcxproj.bat generate_vcxproj.bat] script available in GDAL source code tree to generate project files ([https://msdn.microsoft.com/en-us/library/2208a1f2.aspx .vcxproj]) for Visual Studio [https://msdn.microsoft.com/en-us/library/ee862524(v=vs.100).aspx 2010or later].3 Use [https://github.com/OSGeo/gdal/blob/master/gdal/generate_vcxproj.bat] script available in GDAL source code tree to generate project files ([https://msdn.microsoft.com/en-us/library/2208a1f2.aspx .vcxproj]) for Visual Studio [https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11 2015 or later]. 4 4 5 5 The script generates Visual Studio [https://msdn.microsoft.com/en-us/library/h27k75y5.aspx External Project] (aka [https://msdn.microsoft.com/en-us/library/8y48z24a.aspx Makefile Project]) generated project. Makefile Project almost entirely relies on build configuration defined in GDAL `nmake.opt` (or `nmake.local`) and `makefile.vc` files. … … 8 8 Usage: generate_vcxproj ^<Visual C++ version^> [32^|64] ^<^(*^) project file name^> 9 9 Parameters: 10 1 : Visual C++ version is not the same as Visual Studio version ^( =^> 1 0.0 ^)10 1 : Visual C++ version is not the same as Visual Studio version ^( =^> 14.0 ^) 11 11 2 : Windows platform 32 for Win32 and 64 for Win64 12 12 3 : Base file name, with no path and no extension ^(*^) 13 13 Examples: 14 generate_vcxproj 10.1 32 gdal_vs2010 15 generate_vcxproj 11.0 64 gdal_vs2012 16 generate_vcxproj 12.0 64 gdal_vs2013 14 generate_vcxproj 12.0 64 gdal_vs2013 (not guaranteed to work) 17 15 generate_vcxproj 14.0 64 gdal_vs2015 18 16 }}}
