1 | | TODO |
| 1 | = Generating Visual Studio Project = |
| 2 | |
| 3 | Use [http://svn.osgeo.org/gdal/trunk/gdal/generate_vcxproj.bat generate_vcxproj.bat] script available in GDAL source code tree to generate project files (.vcxproj) for Visual Studio 2010 or later. |
| 4 | |
| 5 | The script generates Visual Studio [https://msdn.microsoft.com/en-us/library/h27k75y5.aspx External Project] (aka [https://msdn.microsoft.com/en-us/library/8y48z24a.aspx Makefile Project]) generated project. Makefile Project almost entirely relies on build configuration defined in GDAL `nmake.opt` (or `nmake.local`) and `makefile.vc` files. |
| 6 | |
| 7 | {{{ |
| 8 | Usage: generate_vcxproj ^<Visual C++ version^> [32^|64] ^<^(*^) project file name^> |
| 9 | Parameters: |
| 10 | 1 : Visual C++ version is not the same as Visual Studio version ^( =^> 10.0 ^) |
| 11 | 2 : Windows platform 32 for Win32 and 64 for Win64 |
| 12 | 3 : Base file name, with no path and no extension ^(*^) |
| 13 | Examples: |
| 14 | generate_vcxproj 10.1 32 gdal_vs2010 |
| 15 | generate_vcxproj 11.0 64 gdal_vs2012 |
| 16 | generate_vcxproj 12.0 64 gdal_vs2013 |
| 17 | generate_vcxproj 14.0 64 gdal_vs2015 |
| 18 | }}} |
| 19 | |
| 20 | 1. Edit `nmake.opt` (or `nmake.local`) to configure desired build options. |
| 21 | 2. Generate projects: `generate_vcxproj.bat 14.0 32 gdal_vs2015` |
| 22 | * `gdal_vs2015.vcxproj` is generated. |
| 23 | * If you build source tree checked out from the repository with [http://svn.osgeo.org/gdal/trunk/autotest/ autotest] folder included, then also `gdal_vs2015_test.vcxproj` is generated for makefile in `autotest/cpp` folder with GDAL C++ tests. |
| 24 | 3. Launch Visual Studio IDE |
| 25 | 4. Go to File > Open > !Project/Solution... |
| 26 | 5. Open project `gdal_vs2015.vcxproj`. |
| 27 | 6. Add project `gdal_vs2015_test.vcxproj` to the solution. |
| 28 | 7. Configure Build Dependencies to build the main project before the test project. |
| 29 | 8. Optionally, you may also have to add in Windows SDK library paths in the project's "VC++ Directories" configuration properties. |
| 30 | 9. Save solution in .sln file. |
| 31 | 10. Build. |
| 32 | |
