Changes between Version 23 and Version 24 of ECW
- Apr 21, 2016, 6:19:03 AM (8 years ago)
ECW
v23 v24 5 5 == Download ECW JPEG SDK == 6 6 7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JP2 SDK" from the [http://download.hexagongeospatial.com/download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8 Hexagon Geospatial] website. The 4. 1or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Hexagon Geospatial/ERDAS.7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JP2 SDK" from the [http://download.hexagongeospatial.com/download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8 Hexagon Geospatial] website. The 4.3 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Hexagon Geospatial/ERDAS. 8 8 9 9 If the out of date libecwj 3.3 SDK can be found, it can also be used. It has significantly different licensing details. Some tickets and discussion below are related to the 3.3 SDK.
