Changes between Version 21 and Version 22 of ECW
- Feb 17, 2016, 8:19:11 AM (8 years ago)
ECW
v21 v22 5 5 == Download ECW JPEG SDK == 6 6 7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JPEG2000 SDK" from the [http://download.hexagongeospatial.com/download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8 Hexagon Geospatial] website. The 4.1 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Erdas.7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JPEG2000 SDK" from the [http://download.hexagongeospatial.com/download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8 Hexagon Geospatial] website. The 4.1 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Hexagon Geospatial/ERDAS. 8 8 9 9 If the out of date libecwj 3.3 SDK can be found, it can also be used. It has significantly different licensing details. Some tickets and discussion below are related to the 3.3 SDK.
