Changes between Version 19 and Version 20 of ECW
- Feb 17, 2016, 7:44:59 AM (8 years ago)
ECW
v19 v20 5 5 == Download ECW JPEG SDK == 6 6 7 In order to use ECW format with GDAL, you need to download Image Compression SDK from the [http:// geospatial.intergraph.com/products/other/ecw/ERDASECWJPEG2000SDK/Downloads.aspx ERDAS] web site. The 4.1 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Erdas.7 In order to use ECW format with GDAL, you need to download Image Compression SDK from the [http://download.hexagongeospatial.com/download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8 Hexagon Geospatial] web site (formerly ERDAS). The 4.1 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Erdas. 8 8 9 9 If the out of date libecwj 3.3 SDK can be found, it can also be used. It has significantly different licensing details. Some tickets and discussion below are related to the 3.3 SDK.
