Changes between Version 26 and Version 27 of ConfigOptions
- Feb 25, 2013, 5:28:26 AM (11 years ago)
ConfigOptions
v26 v27 86 86 === GDAL_DISABLE_CPLLOCALEC === 87 87 88 If set to YES (de afault is NO) this option will disable the normal behavior of the CPLLocaleC class which forces the numeric locale to "C" for selected chunks of code using the setlocale() call. Behavior of setlocale() in multi-threaded applications may be undependable but use of this option may result in problem formatting and interpreting numbers properly.88 If set to YES (default is NO) this option will disable the normal behavior of the CPLLocaleC class which forces the numeric locale to "C" for selected chunks of code using the setlocale() call. Behavior of setlocale() in multi-threaded applications may be undependable but use of this option may result in problem formatting and interpreting numbers properly. 89 89 90 90 === GDAL_FILENAME_IS_UTF8 === … … 276 276 Used by OGRGeometryFactory::organizePolygons(). Defaults to NO. 277 277 278 If set to YES, o granizePolygons(), which is in particular used when reading Shapefiles with Polygon geometry, will use GEOS to check the topological relationship of the subparts of multipolygons. This will slow down processing. There should be no reason to set this option to YES, except for debugging purposes.278 If set to YES, organizePolygons(), which is in particular used when reading Shapefiles with Polygon geometry, will use GEOS to check the topological relationship of the subparts of multipolygons. This will slow down processing. There should be no reason to set this option to YES, except for debugging purposes. 279 279 280 280 === OGR_ARC_STEPSIZE ===
