1 | | GDAL can be built on Win32 platforms using MS VC++ 6.x and MS Visual Studio .NET (C++). The source distribution includes NMAKE compatible makefiles for use from the command shell. For those wanting Visual Studio 7.1 or 8.0 Solution files (instead of the command line nmake files), Ben Discoe normally makes them available on the [http://vterrain.org/Distrib/gdal.html VTP site]. Only the nmake file approach is directly supported by the GDAL maintainers. GDAL also provides automatically generated Visual Studio "Makefile Projects" for version 2003, 2005 and beyond. See [wiki:MakeFileProjects Using Makefile Projects] for details. |
| 1 | GDAL can be built on Win32 platforms using MS VC++ 6.x and MS Visual Studio .NET (C++). The source distribution includes NMAKE compatible makefiles for use from the command shell. For those wanting Visual Studio 7.1 or 8.0 Solution files (instead of the command line nmake files), Ben Discoe normally makes them available on the [http://vterrain.org/Distrib/gdal.html VTP site]. Only the nmake file approach is directly supported by the GDAL maintainers. |
| 2 | |
| 3 | Regarding use of Visual Studio projects check details on: |
| 4 | * [wiki:GeneratingVisualStudioProject Generating Visual Studio Project] |
| 5 | * [wiki:MakeFileProjects Using Makefile Projects] |
152 | | |
153 | | = Generating Visual Studio Project = |
154 | | |
155 | | Use makegdal_gen.bat script available in GDAL source code tree: |
156 | | |
157 | | {{{ |
158 | | Parameters: |
159 | | 1 : Visual C++ version is not the same as Visual Studio version ( => 10.0 ) |
160 | | 2 : Windows platform 32 for Win32 and 64 for Win64 |
161 | | 3 : Base file name, with no path and no extension (*) |
162 | | }}} |
163 | | |
164 | | {{{ |
165 | | Examples: |
166 | | makegdal_gen.bat 10.1 32 makefileproj_vs10 |
167 | | makegdal_gen.bat 11.0 32 makefileproj_vs11 |
168 | | makegdal_gen.bat 12.0 32 makefileproj_vs12 |
169 | | makegdal_gen.bat 14.0 32 makefileproj_vs14 |
170 | | }}} |
171 | | |
172 | | 1. configure nmake.opt (or nmake.local) as usual |
173 | | 2. execute: makegdal_gen.bat 14.0 32 makefileproj_vs14 |
174 | | 3. Launch VS2015 IDE |
175 | | 4. File > Open > !Project/Solution... |
176 | | 5. Select makefileproj_vs14.vcxproj |
177 | | 6. You may also have to add in Windows SDK library paths in the project's "VC++ Directories" configuration properties |
