Changes between Version 22 and Version 23 of Buildbot
- Aug 31, 2014, 12:23:20 PM (10 years ago)
Buildbot
v22 v23 6 6 are done on a daily basis on [http://www.gisinternals.com/sdk/ gisinternals]. The set of optional 7 7 drivers compiled in is rather extensive. The packages with the generated executables can also be downloaded. 8 9 There is also a Appveyor continuous integration build. It builds a minimal GDAL (no optional dependency) in DEBUG mode with Visual Studio 2013 (a.k.a VC12 / MSVC 1800), so as to fit below the 30 minutes limit. The builds can be see at : 10 https://ci.appveyor.com/project/rouault/gdal-coverage . Note that the Python autotest suite is not run due to the timeout issue. 11 12 Travis-CI builds with mingw and mingw-w64 are also available : see trunk_mingw and trunk_mingw_w64 builds at https://travis-ci.org/rouault/gdal_coverage/builds . They include just Proj 4.8.0 as a dependency, and run the autotest suite with Python under Wine 8 13 9 14 == Linux == … … 92 97 93 98 99 == Android == 100 101 Android builds are done under Travis-CI : see trunk_android builds at https://travis-ci.org/rouault/gdal_coverage/builds. 102 103 == MacOS-X == 104 105 MacOS-X builds are done under Travis-CI : see trunk_travis_macosx builds at https://travis-ci.org/rouault/gdal_coverage/builds. They run the autotest suite. 106 107 94 108 == History == 95 109
