Changes between Version 21 and Version 22 of Buildbot
- Jul 10, 2013, 10:05:48 AM (11 years ago)
Buildbot
v21 v22 11 11 * Builds with a rich set of dependencies 12 12 13 A [https://travis-ci.org/#!/rouault/gdal/builds Travis-CI] instance has been [http://svn.osgeo.org/gdal/trunk/.travis.yml configured] to build GDAL and run of the Java, Perl and Python tests for each SVN commit in trunk. For that, [https://github.com/rouault/gdal a git clone of GDAL] is regularly synchronized with SVN. 13 A [https://travis-ci.org/#!/OSGeo/gdal/builds Travis-CI] instance has been [http://svn.osgeo.org/gdal/trunk/.travis.yml configured] to build GDAL and run of the Java, Perl and Python tests for each SVN commit in trunk. For that, [https://github.com/OSGeo/gdal a git clone of GDAL] is regularly synchronized with SVN. 14 15 [https://github.com/rouault/gdal_coverage Another github repository] is slightly modified to generate coverage information from the run of the GDAL autotest suite. The results are available [http://rawgithub.com/rouault/gdalautotest-coverage-results/master/coverage_html/index.html here]. 14 16 15 17 The result of builds is also published on #gdal on irc.freenode.net and emailed to gdal-commits at lists.osgeo.org (only failures, or failure->success transitions are notified). It seems that a full build with tests takes about ~ 10 minutes (but I guess this may vary according to the load of the service). … … 19 21 For GDAL committers that wish to tweak .travis.yml at the root of the trunk, you can find the syntax of that file at http://about.travis-ci.org/docs/user/build-configuration/ . This file contains the instructions to download dependency libraries, setup databases (PostgreSQL, MySQL) that will be used for testing, build GDAL and its bindings, and run the tests. 20 22 21 The OS os the Travis-CI virtual machines is Ubuntu 12.04 i386. The GDAL build is configured with almost any possible dependencies to external libraries :23 The OS os the Travis-CI virtual machines is Ubuntu 12.04 64bit. The GDAL build is configured with almost any possible dependencies to external libraries : 22 24 23 25 {{{
