Changes between Initial Version and Version 4 of Ticket #994
- Apr 9, 2007, 9:52:25 AM (14 years ago)
Ticket #994 – Description
initial v4 1 {{{ 2 When you use ogr2ogr to import vmap0 layers into PostGIS then there is no option 3 to append layers to the existing layer if available and create when it's not 4 available. 1 When you use ogr2ogr to import vmap0 layers into PostGIS then there is no option to append layers to the existing layer if available and create when it's not available. 5 2 6 3 A option like -createifnolayer (or a better name?) would be highly appriciated. 7 4 8 This will save a lot of scripting to import all 4 vmap0 layers into postgresql 9 in a single run... 10 }}} 5 This will save a lot of scripting to import all 4 vmap0 layers into postgresql in a single run...
