Changes between Version 1 and Version 5 of Ticket #976
- May 31, 2007, 12:15:17 PM (17 years ago)
Ticket #976
- Property Status new → assigned
- Property Keywords hole polygon ring shapefile added
Ticket #976 – Description
v1 v5 3 3 OGR2OGR utility converts vector data into shapefile in a wrong way. Here is a description of the problem. 4 4 5 I have a shapefile, for example with a polygon and two holes (see attached pictures, holes are numbered as hole 1 and hole 2). Ordering is CW for exterior and CCW for interiors, see the shpdump for initial file: 5 I have a shapefile, for example with a polygon and two holes (see attached [attachment:ticket:976:figure.jpg figure.jpg], holes are numbered as hole 1 and hole 2). 6 7 Ordering is CW for exterior and CCW for interiors, see the shpdump for initial file: 6 8 {{{ 7 9 Shapefile Type: Polygon # of Shapes: 1
