Changes between Initial Version and Version 1 of Ticket #6448
- Apr 8, 2016, 5:48:51 AM (8 years ago)
Ticket #6448 – Description
initial v1 1 When the value of GDALWarpOptions::dfWarpMemoryLimit is set to be very large, such as 10 GB, the program will fail, because the size of allocated memory overflows. The original is as below:1 When the value of GDALWarpOptions::dfWarpMemoryLimit is set to be very large, such as 10 GB, the program will fail, because the size of allocated memory overflows. The original code is as below: 2 2 3 3 gdalwarpoperation.cpp line 2059
