Changes between Version 1 and Version 2 of Ticket #6223
- Nov 16, 2015, 10:05:59 AM (8 years ago)
Ticket #6223 – Description
v1 v2 1 In r15574, put a volatile modifier on nTempFileCounter. This looks to be protect from multithreaded race cases between callers of CPLGenerateTempFilename where more than one thread might get the same tempfile number. Would it be better to call CPLAtomicInc and use the result of that? If so, should I drop the volatile?1 In r15574, you put a volatile modifier on nTempFileCounter. This looks to be protect from multithreaded race cases between callers of CPLGenerateTempFilename where more than one thread might get the same tempfile number. Would it be better to call CPLAtomicInc and use the result of that? If so, should I drop the volatile? 2 2 3 3 e.g. … … 9 9 (unsigned int)(CPLGetPID() & 0xFFFFFFFFU), nTempFileCounter++ ); 10 10 }}} 11 Would become this :11 Would become this. 12 12 {{{#!c++ 13 13 static int nTempFileCounter = 0; 14 14 CPLString osFilename; 15 15 osFilename.Printf( "%s%u_%d", pszStem, 16 static_cast<unsigned int>( CPLGetPID() & 0xFFFFFFFFU 17 CPLAtomicInc( nTempFileCounter) );16 static_cast<unsigned int>( CPLGetPID() & 0xFFFFFFFFU), 17 CPLAtomicInc(nTempFileCounter) ); 18 18 }}} 19 19
