Changes between Initial Version and Version 1 of Ticket #5934
- Apr 22, 2015, 12:27:16 PM (9 years ago)
Ticket #5934 – Description
initial v1 1 Hi, 2 1 3 I spot an issue with the VSIRename function using the memory filesystem driver. The problem is that it does not properly handle renaming of directories. I know not whether this feature was officially supported. However, I took the liberty of writing a replacement code, which seems to work, and I thought of sharing it. The following is what I came up with. 2 4
