Changes between Initial Version and Version 1 of Ticket #5575
- Jul 17, 2014, 8:18:53 PM (10 years ago)
Ticket #5575 – Description
initial v1 3 3 I am a new GDAL user, when I compile GDAL-1.11.0, want to enable FileGDB read/write support, according to official guidance document, do the following configuration: 4 4 5 FGDB_ENABLED = YES 6 # FGDB_PLUGIN = YES 7 FGDB_SDK = C: \ FileGDB_API_SDK \FileGDB_API_VS2010_1_3 8 FGDB_INC = $ (FGDB_SDK) \ include 9 FGDB_LIB = $ (FGDB_SDK) \ lib \ FileGDBAPI.lib 5 FGDB_ENABLED = YES[[BR]] 6 # FGDB_PLUGIN = YES[[BR]] 7 FGDB_SDK = C: \ FileGDB_API_SDK \FileGDB_API_VS2010_1_3[[BR]] 8 FGDB_INC = $ (FGDB_SDK) \ include[[BR]] 9 FGDB_LIB = $ (FGDB_SDK) \ lib \ FileGDBAPI.lib[[BR]] 10 10 11 11 Compile all goes well, when I try to read a FileGDB, no problem; But when I want to create a new layer, the correct error, tested with TestCapability (Ogr.ODsCCreateLayer), the result is "false". The same build configuration, there is no problem in the GDAL-1.9.2 version, but can’t support DeleteFeature capability… I am very confused, please enlighten master, thank you ~
